Max distance to place an object so it won't slide (torque and friction)
The problem involves an object placed on a slanted surface that rotates around a vertical axis. The objective is to determine the maximum distance from the rotation axis at which the object can be placed without sliding, given the angle of the slope, the mass of the object, and the coefficient of static friction.
  • Participants discuss the effects of torque and centripetal acceleration on the forces acting on the object. There are attempts to relate the free body diagram to the static equations, and questions arise about the lack of specific measurements and how to approach the problem without them.
Some participants have provided guidance on identifying relevant forces and components, while others express confusion about the implications of the rotating frame of reference and the need for additional measurements. Multiple interpretations of the problem setup are being explored, but no consensus has been reached.
Participants note the absence of specific distances or measurements in the problem statement, which complicates the analysis. There is also mention of the need to consider the effects of the inclined plane and the forces acting on the object in a rotating system.
Femme_physics
http://img196.imageshack.us/img196/3732/31591397.jpg
An area slanted at an angle of 30 degrees turns aroun a vertical axis as depicted in drawing. The period time of the rotational motion is 3 seconds. On the surface is an object whose mass is 6kg.
The static friction coeffecient between the body and the surface is 0.4
Calculate at which max distance (from the rotation axis) can the object be placed so it won't slide up the surface?
I wasn't really sure what to do! How does the torque on the surface affects the forces in my static equations? I just drew a free body diagram and tried solving for stuff randomly. I've no idea how to approach the solution to this. Any help/hints?
http://img405.imageshack.us/img405/8708/80167579.jpg
You're on the right track with your FBD! :smile:
But you didn't account yet for the centripetal acceleration.
The 3 forces you drew have to add up to ma.
You also didn't mark the distance from the rotation axis yet, which is what you have to solve.
Btw, which torque on the surface do you mean?
You want the mass move along a horizontal circle with given angular velocity. What has to be the resultant of all forces?
Remember N is a force of constraint. It is equal to the normal component of gravity if the slope is in rest, but it turns now...
ehild
Ohhh, ILS beat me
I mean centripetal acceleration (apparently!), sorry :)
w00t!:approve::smile:o:) (oh no, smiley infection is moving topics!)
This is another weird thing. They didn't write any distances or measurements! So that's another bump in the road that I'm not sure how to maneuver through.
(illustration to help analogy)
http://img810.imageshack.us/img810/529/bumproad.jpg --------------------------
Okay, first things first, I need to find centripetal acceleration. V squared/R. Tricksy, since I don't have R. This entire thing is so confusing without ANY given measurements at all. As far as I'm concerned, this thing can be in nanometers. Okay, yea, so the object is 6kg so it doesn't make sense. Still, shouldn't they have written distances?
I really lost you here, especially in the first sences: "You want the mass move along a horizontal circle with given angular velocity. What has to be the resultant of all forces? "
Can you elaborate for me a bit, please?
Ohhh, ILS beat me
He's fast isn't he? :wink:
The wedge or what turns round, and the mass moves together with it. As it does not slide up or down, it moves at constant height, does not it? The period of rotation is given so you can get the angular speed.
No, Physicsforums was too slow,:wink: it just refused to accept my answer, it does such things sometimes...
If it MOVES on an inclined plane, how can it be at a constant height?
No, Physicsforums was too slow, it just refused to accept my answer, it does such things sometimes...
I got 504 gateway timeout myself if this is what you're referring to. :-/
Well, this time I was slow!
But then, I took my time enjoying the drawing and the smileys and all! :smile:
I've just been sitting here, dreaming away! :blushing:
So mark a horizontal distance from the block to the axis of rotation.
There! You have R, which is also the distance they ask you to solve.
Together with all the other measurements (mass, angle, coefficient of friction, frequency), you have all you need! :smile:
The point at which the object starts slipping is the point at which you no longer have any additional forces with which to apply a greater centripetal force. Remember, you don't know r because what you're trying to solve for is r.
Applying these equations should get you rolling:
w = 2pi / T where T is your period.
ac = rw^2 where ac is your centripetal acceleration, and w is angular velocity. You could also find v, and us ac = v^2 / r, whatever you prefer.
Something to keep in mind: you're rotating horizontally, not parallel to the plane the block's on, so keep your trig straight. Not that you'll have trouble with this, it's just some stuff I like to remember when solving problems.
See if you can't get going with that.
The mass does not move along the plane. The question is what the maximum distance is from the axis so it does not move up. The body is in a rotating frame of reference and feels a centrifugal force pointing away from the axis. That has a component along the slope. I do not like accelerating frames of reference (neither do you, I assume), but without static friction the body would move with respect to the slope not only up or down, but sideways, too. So we assume that the body is in rest with respect to the slope and do "reverse engineering" to find the forces necessary to that.
That is its custom, and I have lost my letters quite often. Now I know what to do, copy my answer and go out from PF and try again a little later. :smile:
ehild
Actually, I found I it suffices to click "refresh", and when asked to resend, click "Resend".
Wait a couple of minutes and try again if you get another gateway timeout. :wink:
thanks, but I am usually get bored with PF if it is so idle and go somewhere else. I do not have much time to wait :wink:
ehild
Together with all the other measurements (mass, angle, coefficient of friction), you have all you need!
Actually, if I'm looking at the formula for centripetal acceleration, I don't have V and I don't have R. So how can I solve for centripetal acceleration?
*covers you with a blanket*
Oh yea, been doing that since 2001. I don't be trusting this "interweb" technewlogy...
Are you saying I'm not posting enough questions? :devil:
Rest be assured, this is my folder, each file contains 7 questions :)
http://img863.imageshack.us/img863/7837/seethisf.jpg I'll be spending my June here till I MASTER this stuff (master it like splinter from Ninja turtles!)^^
Though, hopefully I'll figure most of it on my own and won't have to poke you guys. I actually had a 5 questions winning streak before flunking with this one. Sorry for going off-topic! :) My next reply will be about the exercise provided I have no more distractions.:shy:
So, Apop, ehild, ILS, thanks. Will get to it :)
It's the third dimension! :smile:
The block is actually coming out of the page hurtling toward you!
And just before it touches you, it turns around, dives into and through the page, completing its circle!
And it that's not enough, it only takes 3 seconds to do all that! :cool:
Its speed is v = ω x R
Its centripetal acceleration is a = v2 / R = ω2 R
Oh really!?
*swings arms defensively!*
Phew. I really should take a little more distance from my problems, next time! Of course, if I had any measurements... *grumbles*...
1 equation, two unknowns
Oh really!?
Really :approve:
I did solve for omega
2 unknowns, 1 equation!
I might have mistranslated. It said "so that the object won't move up the plane"
Yes, I know, but it is weird if moving down is allowed. In this case it gets closer to the axis, but you want the maximum distance. And the coefficient of static friction is given, that suggests no motion with respect to the plane. Agree? :smile:
ehild
I guess if it's in nanometers, there's no risk of the block hitting you! :smile:
But then, if it's in meters...
Hmm, let's see...
Sum of vertical forces = 0
Sum of horizontal forces = m a
a = ω2 R
Fs = 0.4 x N
Unknowns are: N, Fs, a, and R.
That is...
4 equations with 4 unknowns! :smile:
And you can probably fill a couple of those in, one after the other! :wink:
Oh, I know, you just don't want to do the work! :biggrin:
I agree there's no motion at the Y axis! Yes, I do.
Oh, god, one of those...
True, I do shy away from multiple equations and multiple unknown problems. They're time consuming, and less about physics, more about math, and waste half my day trying to solve them. :P
I do have a calcular function for 3 eq 3 unknowns, but I don't think I have one for 4 eq 4 unknowns. *pouts*
Alright. I'll get cracking after diving my head in sand.^^
Thank you :)
Do not let you frighten away by any number of unknowns. After all, you are student of engineering are not you?
Just write up all horizontal and vertical force components, and find those two equations for the horizontal components and the vertical ones. Basically, you have two unknowns, N and R, as you can take Fs=0.4N, and parallel to the slope. The centripetal force contains only R as unknown, as it is Rw^2 and you know the angular speed. Go ahead, show your equations.
ehild
I wouldn't really call it 4 equations 4 unknowns. Just a bit of untangling. 4 equations 4 unknowns is IMO when you can't get any numeral result (without an unknown) without using all the 4 equations. Just IMHO. :)
Is that it?
http://img821.imageshack.us/img821/4932/requals.jpg
((how I got to the other results is in the first attempt))
(but you're right, I shouldn't be afraid of multiple equations. I'm not, really!)
I'm afraid I haven't been able to protect you from them!
But I'll try to help you confront them! :smile:
Thank you :)
Well, with ehild's suggestion I think it would fit in your calculator! :wink:
Is that it?
No, this is not quite it.
You're using an N that should be a little bigger, since it also has to contribute to the resulting centripetal acceleration.
Fs will be a little bigger then as well, also contributing to the centripetal acceleration.
I'm not quite clear what you did with Σ Fx here, but I suspect you did not account for the fact that the centripetal acceleration is horizontal and not along the slope, which you defined as the x axis.EDIT: Btw, the measurement unit is not quite unknown, since you have the units Newtons, kilograms, and seconds.
If you consider that a Newton is actually a derived unit in kilograms, meters, and seconds, you'll see that your measurement unit for R will be meters! :wink:
I'm confused, isn't N just
Sum of all forces on Y = -Wcos(30)+N = 0Therefor I should have the correct figure for N, no?
No, you left out the needed centripetal acceleration.
Perhaps you should think of it this way.
The centrifugal pseudo force presses the block extra hard against the slope.
This generates an increase in normal force...
If you would increase the circular speed, the centrifugal force will make the block slide up the slope (until it falls over the edge! :wink:)
In order to find centrifugal force, I need R, in order to find R, I need N, which is more than W cos(30) since I have to consider the centrifugal addition to the normal force. Great, I'm in a dead end, going in circles :(
I think you have studied systems of equations with two or more variables. Just find out the relation between the forces. You are a clever girl, you can do it.
ehild
:frown::frown:
I want to prove your confidence in me right, I really do!
Sum of all forces on X = Fs + Wcos(60) = 0
Fs = N x 0.4
a = v squared/R
a = omega squared times R
Is this everything I need to solve? ILS wrote to me
But he didn't write what those forces are! What I wrote my attempts, he told me I'm wrong, now I'm just losing the string.
Well, I'll be going on the bus back home soon so I'll probably tackle this exercise in only a few hours from now. Thanks^^
REALLY appreciate all your help! :)
Think: The object accelerates. How can it be if the sum of all forces is zero? ehild
I'll say it one more time: your period, which is given to you, is related to omega (w) through w = 2pi / T where T is your period. So you can find w.
Centrifugal force is a false force. You won't include it in your free body diagrams at all. As for centripetal force, it is only caused by existing forces (friction, normal, etc), it is in itself not an actual independent force.
What you want to do is set your centripetal force (Fc = mrw^2) equal to all of the horizontal force components (this is where your free body diagram will help). You can find all of those force components. Thereafter you will have a system of equations with only one variable unaccounted for, that variable being r. R is the horizontal distance from the axis of rotation, and using the fact that you have a 30 degree angle, you can find the block's position on the incline using trig.
Yes, the block is going around in circles.
And if you sit on it, you'll probably get dizzy! :smile:
Well, I'm trying to let you wrestle a bit on your own with this problem.
Takes a bit of effort though, because I'd like to give you the world, and not just this block. :redface:
Let me give you a hint anyways.
How does "a" figure in your sums of forces?
See you later then! :smile:
That I found even before posting the problem-- as a proof you can see my original post where I show that I found omega!
OHHHHHHHHHHHHHHHHHHHHHHH! Now I get the meaning of why ILS keeps calling it a pseudo-force :)
Why am I doing it? centripetal force is ma, yes? So I'm doing sum of all forces on x = ma, which is exactly what I've done! is this just sum of all forces = ma?
Well, I know the equation to get R but I was told that my normal force was wrong in that equation. But I do know the final step once I have the right normal force.
I don't need anymore help getting dizzy right about now!
Com'here *grabs the triangle and does a trapping headbutt followed by a battering ram, dropkick and an eye poke*
Rawr!1
Can you rephrase that, please? I don't understand
  • · Replies 20 ·
  • · Replies 45 ·
9K
