| New Reply |
Transverse wave along a string |
Share Thread |
| Jun6-11, 12:44 AM | #1 |
Equation of transverse wave traveling along a string is: y=6cm sin(0.02[tex]\pi[/tex]x-4[tex]\pi[/tex]t) where x and y are in cm and t is in seconds A)find max transverse speed of a particle in the string B)Find transverse displacement of a particle in the string at x=3.5cm and t=0.2s 2. Relevant equations [tex]\mu[/tex]max=[tex]\omega[/tex]ym y(x,t)=ym*sin(kx-[tex]\omega[/tex]t) 3. The attempt at a solution A) I got [tex]\mu[/tex]max = 4[tex]\pi[/tex]*(.06m) = 0.75m/s B) y(x,t)=0.06m*sin(.02[tex]\pi[/tex](.035m)-4[tex]\pi[/tex](0.2)) = -0.035m Are these correct? |
| Jun6-11, 03:34 AM | #2 |
Recognitions:
Copy and paste these greek letters and write an equation in one line.
ehild |
| Jun6-11, 08:15 PM | #3 |
Mentor
I'll try fixing up the LaTeX for you:
EDIT2 -- See my later post for how to see the LaTeX equations in my post. |
| Jun6-11, 09:03 PM | #4 |
Yes, that is correct. Should be u max instead of the subscript of just m. But I was just wanting someone to check my answers for me. I would just convert them to cm then.
| Jun6-11, 09:36 PM | #5 |
Recognitions:
The constants in your given equation [itex] y=6 sin(0.02{\pi}x-4{\pi} t) [/itex] don't have units attached, but given that the problem statement specifies cm and seconds for x and t, it is (hopefully) reasonable to assume that you should have to use values specified in these implied units in the formula. That is, when you plug in 3.5 cm for x, better make it "3.5" rather than "0.035" .
If the formula had included these implied units it might look something like: [tex] y(x,t) = 6cm \; sin \left( \frac{0.02 \pi}{cm}x + \frac{4 \pi}{sec}t \right) [/tex] |
| Jun7-11, 11:59 AM | #6 |
Mentor
Instead, highlight the equation you want to see (using click-drag with your mouse), then right-click the equation and select Show Source. Expand the box to see what the equation source is -- there is a single set of tex tags around each line of source. |
| New Reply |
Similar discussions for: Transverse wave along a string
| Maximum transverse velocity of a wave along a string | Introductory Physics Homework | 0 | ||
| Forces on a String with a Transverse Wave | Introductory Physics Homework | 1 | ||
| Traveling Wave Model: transverse wave on a string | Introductory Physics Homework | 8 | ||
| Need help fast with transverse wave on string! | Introductory Physics Homework | 1 | ||
| How long does it take this transverse wave to travel along a string | Introductory Physics Homework | 2 | ||
