Relativistic H/-H in a neutral beam accelerator
A neutral beam accelerator is utilized to accelerate hydrogen and antihydrogen atoms to relativistic velocities, allowing for the analysis of photon energies resulting from their annihilation. Identical photodetectors are employed at both the starting point and the endpoint of the accelerator to measure the spatial and spectral distribution of photon energies. The discussion focuses on the potential separation of momentum components from the measured energies and the calculation of non-photon energy, referred to as 'waste' energy. The inquiry is motivated by the need for precise data collection and analysis in high-energy physics experiments.
  • Understanding of relativistic physics principles
  • Familiarity with photon detection technologies
  • Knowledge of particle-antiparticle annihilation processes
  • Experience with energy distribution analysis in high-energy experiments
  • Research the principles of relativistic particle acceleration
  • Learn about photon energy measurement techniques in particle physics
  • Investigate methods for calculating non-photon energy in annihilation events
  • Explore the design and functionality of neutral beam accelerators
Physicists, researchers in high-energy particle physics, and students studying relativistic dynamics and photon detection methodologies will benefit from this discussion.
danR
A beam of hydrogen and antihydrogen atoms is accelerated to relativistic velocities by means of a neutral beam accelerator.
Identical photodetectors gather and record the photon energies of annihilating H and -H at both ends of the accelerator: where the atoms start; and at the end of the apparatus, where the velocity of the atoms is maximum.
Comparing the spatial and spectral distribution of the energies of the photons at either end, how do they compare? Can the momentum component of the measured energies be separated out? Can the non-photon (let's call it 'waste') energy be calculated? Assume the budget is large and the detectors are wide enough to capture all the decay products as photons, but if that's confused wording, do your best with what came before.
I'll tell you the motivation this question, but I want to be paid, before I say what I want to buy.
I'll have to ask around the university here. They have some CERN researchers.
  • · Replies 20 ·
  • · Replies 87 ·
9K
