How to fix EOF error when transitioning from Windows to Linux?
  • Thread starter Thread starter swartzism
    Unix Windows
The discussion revolves around an EOF error encountered when transitioning code from a Windows environment (Cygwin) to a Linux environment (Fedora). Participants explore potential causes related to file formats, permissions, and error handling in the context of reading data files.
  • One participant reports an EOF error when running previously working code on Linux, questioning what might need to change in the transition.
  • Another participant suggests considering whether the file is opened as text or binary, indicating this could affect the EOF error.
  • A participant mentions the possibility of insufficient permissions for reading/writing the file, given they are not operating as root on the Linux system.
  • One reply requests more detailed information about the error and suggests providing outputs from specific commands to diagnose the issue further.
  • Another participant notes the difference in file formats between Windows and Linux, particularly regarding newline characters, and suggests using the dos2unix tool to address potential newline issues.
  • A participant emphasizes the importance of proper error handling in the code to obtain more informative error messages when file operations fail.
Participants express differing views on the potential causes of the EOF error, with no consensus reached on a single solution. Multiple hypotheses regarding file format differences, permissions, and error handling are presented.
Participants have not resolved the specific cause of the EOF error, and assumptions about file formats and permissions remain unverified. The discussion reflects a variety of approaches to diagnosing the issue without definitive conclusions.
swartzism
I am getting a confusing EOF error. I have working code which I have tested in Cygwin on Windows, but now that I am running the same code on Fedora Linux, I am getting an EOF error in a data file that I know works. Is there something I need to do in the transition from Windows to Linux to prevent this?
Thanks
Technology news on Phys.org
I can be completely off with my thinking, but is it a text, or binary file? And is it opened as text, or as binary?
It's a text file opened correctly as a text file. I'm exploring the idea that I don't have the proper permissions to read/write since I'm not root on this Linux computer.
Thanks for the reply.
Hi swartzism! Welcome to PF! :smile:
You'll have to give us a bit more information to help you.
There are a number of reasons why what you're doing might fail.
Can you give a more detailed description from the error that you're getting?
Perhaps what does work and what doesn't?
Can you provide us with the output of the following commands?
$ ls -l filename
$ od -tx1 filename
where filename is your data file?
Your code should be capable of giving you a more useful error message than that. If I knew the language, I might be able to show you how to make it give you more information (assuming it's one I know).
For example, in C (keeping in mind I've not tested it, it's from memory, but that should give you the gist):
Code:
#include <stdio.h>
#include <errno.h>
#include <string.h>
#define INPUT_FILENAME "somefile.txt"
int main()
    FILE *fp = NULL;
    errno = 0;
    fp = fopen(INPUT_FILENAME, "r");
    if (errno != 0)
        int err = errno;
        fprintf(stderr, "Error opening file \"%s\" (%d): %s\n", INPUT_FILENAME, err, strerror(err));
        return -1;
Important edit: fopen returns a NULL and sets errno on error. I'm not checking for the null, but it's just a demonstration for how to use errno, not an example of perfect error handling in fopen. Keep that in mind.
A windows text file and a linux text file have different file formats (specifically, in regard to newlines).
It would be much easier to pin down the error if you could show us code or otherwise better explain what the error actually is.
I usually have to run dos2unix to fix the newlines on my Windows text files that I've transferred to Unix.
  • · Replies 66 ·
10K
