Creation or destruction of particol in the state function
The discussion centers on the mathematical treatment of particle creation and destruction within quantum mechanics and quantum field theory. It highlights that traditional quantum mechanics, governed by the Schrödinger equation (Hψ = iħ d(ψ)/dt), cannot accommodate variable particle numbers due to its finite degrees of freedom. The resolution is found in quantum field theory, which allows for an infinite number of degrees of freedom, enabling the description of systems with varying particle counts through the use of creation and annihilation operators that transition between different particle subspaces.
  • Understanding of the Schrödinger equation in quantum mechanics
  • Familiarity with quantum field theory concepts
  • Knowledge of Hilbert spaces and their applications in physics
  • Basic grasp of creation and annihilation operators
  • Study the principles of quantum field theory and its mathematical framework
  • Learn about the role of Hilbert spaces in quantum mechanics
  • Explore the function and application of creation and annihilation operators
  • Investigate the implications of variable particle numbers in quantum systems
Students and professionals in theoretical physics, particularly those focusing on quantum mechanics and quantum field theory, as well as researchers interested in particle physics and its mathematical foundations.
spocchio
Hi,
I've studied a bit nuclear physics, and
I don't get how the mathematics under the creation and destruction of particles is handled.
if shrodingher equation leads a state vector in the usual way Hpsi=ih d(psi)/dt
let's suppose I've N particles and psi=psi(q1...qn)
so, if a new particle is created...does it mean my psi become psi=psi(q1...qn+1) ??
how can a mathematical frame handles this process?
the question could be reformulated as:
what happen to the state function when a new particle is created?
Ordinary quantum mechanics can only deal with definite numbers of particles, pretty much for exactly the reason you have described. If you have a system with only a finite number of degrees of freedom, you can't describe a variable number of particles.
The solution to the problem lies in quantum field theory. Here, you have an infinite number of degrees of freedom (finitely many for every point in space) so you can happily describe as many or as few particles as you like.
The Hilbert space has a one-particle space described by Ψ(q1), a two-particle space described by Ψ(q1, q2), and so on. The creation and annihilation operators take you from one subspace to another.
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 183 ·
20K
