Solve Work-Energy Question with Physics Problem | Elastic Cord and Sandbag
  • Thread starter Thread starter pulau_tiga
    Work-energy
The physics problem involves a sandbag with a mass of 23.2 kg attached to an elastic cord with a force constant of 382.0 N/m, initially unstretched at 5.44 m. The correct calculation shows that the sandbag drops a total distance of 8.6 m below the railing before momentarily coming to rest. The analysis utilizes the conservation of energy principle, equating gravitational potential energy and elastic potential energy. The final position is determined by solving the equation derived from energy conservation, leading to the conclusion that the sandbag stretches the cord significantly beyond its initial length.
  • Understanding of gravitational potential energy (Ug) and elastic potential energy (Ue)
  • Familiarity with the conservation of energy principle in physics
  • Knowledge of basic algebra for solving equations
  • Experience with spring constants and Hooke's Law
  • Study the conservation of mechanical energy in isolated systems
  • Learn about Hooke's Law and its applications in real-world scenarios
  • Explore examples of energy conservation problems in physics textbooks, such as "Fundamental Physics" by Halliday/Resnick/Walker
  • Practice solving problems involving elastic potential energy and gravitational potential energy
Students studying physics, educators teaching mechanics, and anyone interested in understanding energy conservation in elastic systems.
pulau_tiga
Hi,
I am having diffculty with a physics problem. If anyone could help me out it would be greatly appreciated.
Question:
One end of a long elastic cord is tied to the railing of a high bridge. The other end is tied to a sandbag with a mass of 23.2 kg. The unstretched length of the elastic cord is 5.44 m and its force constant is 382.0 N/m. The sandbag is dropped from the railing. How far does it drop before coming to rest momentarily before being pulled back up by the cord.
My answer, so far:
Known: k=382.0 N/m; Xinitial = 5.44 m; m of bag = 23.2 kg.
Unknown: Xfinal = ?; W =?
I know that W = F(Xfinal) and that W = Efinal - Einitial
Therefore,
F(Xfinal) = Efinal - Einitial
F(Xfinal) = 1/2k(Xfinal)^2 - 1/2k(Xinitial)^2
228 N (Xf) = 1/2(382.0 N/m)(Xf^2) - 1/2(382.0 N/m)(5.44 m)^2
By rearranging and solving for Xf
Xf = -4.87 m; +6.09 m
Rejecting -4.87 m, my answer is 6.09 m, however it is not right.
Does anyone see what I have done wrong??
If anyone could help me out, it would be greatly appreciated.
Thanks
One thing to point out before discussing the physics: By "How far does it drop" I assume they mean how far below the railing. (Don't forget the unstretched length.)
I find it a bit hard to follow what you've done. (Not enough coffee, perhaps?) In any case, here's how to analyze this. At its lowest point call the gravitational PE = 0, so all you have is spring PE. At the initial point (the railing) all you have is gravitational PE (measured from the lowest point--don't forget the unstretched length). Since energy is conserved, set them equal.
Hi Ho! ^_^
I found a question like this in Fundamental Physics 6th Edition by Halliday/Resnick/Walker.
Page 148-149, Sample Problem 8-4.
Therefore, I can answer your question.
1. Let's take an isolated system consists of: earth-bridge-sandbag-cord.
2. Because it's an isolated system without any external force acts on it, there's no work done to this isolated system. (Work is act of transferring energy)
Thus, Work = (delta)Energy of this system = 0
(delta)K + (delta)U gravitation + (delta)U elastic = 0
3. For the first condition, that's before the sandbag is thrown,
K = 0 (it is at rest)
Ug = 0 (taking the bridge as the referential point, y = 0)
Ue = 0 (the rope is at rest)
4. For the last condition,
K = 0 (it stops momentarily before being pulled back up by the cord)
Ug = mg(h+z) where h is the last position before the cord is scretched by the sandbag and z is the last scretched position of the rope (when it momentarily stops).
Ue = 0.5(k)(z^2)
5. (delta)K + (delta)U gravitation + (delta)U elastic = 0
0 + mg(h+z)+0.5(k)(z^2) = 0
23.2(9.8)(-(5.44+z))+0.5(382.0)(z^2) = 0
z = 3.208578894
I use -(5.44+z) because I use the bridge as y = 0. So all position below the bridge will be negative in sign.
6. Therefore, the answer is 8.648578894 m. That's 8.6 m.
