Can Runge-Kutta be used for problems with more than 2 independent variables?
  • Context: Graduate
  • Thread starter Thread starter hoomanya
    Runge kutta
The Runge-Kutta method is applicable only for problems with a single independent variable, specifically time (t). In the discussed scenario, the equation dy/dt = f(u, v, r) requires that all variables (u, v, r, L) be expressed as functions of t for the method to be valid. The necessity of uncoupling r and L is highlighted, as L can potentially be expressed in terms of u and v, complicating the implementation. Therefore, for successful application of Runge-Kutta, all variables must be appropriately defined in relation to the independent variable.
  • Understanding of the Runge-Kutta method
  • Familiarity with ordinary differential equations (ODEs)
  • Knowledge of variable dependency in mathematical modeling
  • Basic skills in expressing functions of multiple variables
  • Research the application of the Runge-Kutta method in solving ordinary differential equations
  • Explore techniques for variable uncoupling in mathematical models
  • Learn about expressing multiple variables as functions of a single independent variable
  • Investigate alternative numerical methods for systems with multiple independent variables
Mathematicians, engineers, and researchers dealing with differential equations, particularly those exploring numerical methods for complex systems with multiple variables.
hoomanya
Hi,
I am trying to use the Runge-Kutta method for a problem that looks like this:
dy/dt= f(u,v,r)
where y= r*L
I was wondering if dy/dt can be a function of more than 2 independent variables?
Also do I need to do some kind of uncoupling of r and L? (I think L can be in a way expressed in terms of u and v but that would make things even more complicated I guess. )
Thanks,
H
Runge-Kutta works for only 1 independent variable, i.e t in this problem. Ultimately, u, v, r, L must all be expressed as functions of t for Runge-Kutta to work.
  • · Replies 65 ·
10K
  • · Replies 31 ·
