Vorticity where angular velocity is function of r
The discussion revolves around the calculation of velocity fields and vorticity distributions for fluid dynamics scenarios where angular velocity is a function of radius, \(\Omega(r)\). The user, identified as catboy, questions the validity of the provided velocity components \((u_x, u_y, u_z) = (-\Omega(r), \Omega(r), 0)\), asserting that both x and y components cannot be identical. The vorticity calculations for three specific cases—(a) \(\Omega = q/r\), (b) \(\Omega r^2 = k\), and (c) \(\Omega^2 r = G*M/r^2\)—are derived using cylindrical coordinates, leading to distinct vorticity results. Desconfusing in Madrid points out that the book's solution is incorrect, emphasizing that the dimensions of velocity components are misrepresented.
  • Understanding of fluid dynamics principles, particularly angular velocity and vorticity.
  • Familiarity with cylindrical coordinate systems in physics.
  • Knowledge of vector calculus, specifically the curl operator for vorticity calculation.
  • Basic concepts of conservation of angular momentum in fluid flow.
  • Study the derivation of velocity fields in cylindrical coordinates.
  • Learn about the physical significance of vorticity in fluid dynamics.
  • Explore the implications of angular velocity variations in vortex dynamics.
  • Investigate the mathematical treatment of flow around vortices, particularly in astrophysical contexts.
Students and professionals in fluid dynamics, physicists studying rotational flows, and engineers involved in vortex-related applications will benefit from this discussion.
catboy
I am given, in each of three cases, an angular velocity [tex]\Omega(r)[/tex] and am told to assume no axial (z) velocity i.e., [tex]u_z = 0[/tex]. I am asked to
(1) find the velocity field in cartesian coordinates
(2) find the vorticity distribution in threee cases.
(1) As setup, the problem asks me to "Show the velocity components are given by [tex](u_x,u_y,u_z) = (-\Omega(r), \Omega(r), 0)[/tex]".
This doesn't seem possible to me...how can both x and y components of the velocity field be the same? I keep coming up with the like of, for a given r:
[tex]u_x = - r * \Omega(r) * \sin(\theta)[/tex]​
[tex]u_x = r * \Omega(r) * \cos(\theta)[/tex]​
where [tex]\theta = \Omega(r) * t;[/tex]
Nevertheless, the supplied answer to (1) is [tex](u_x, u_y, u_z) = (-\Omega(r), \Omega(r), 0)[/tex] and it seems to contradict my later assertion that (in cyl coords) [tex]u_r = 0[/tex].
For (2), I am asked to find the vorticity in three cases:
a) [tex]\Omega = q/r[/tex] (typ. flow around strong concentrated vortex)
b) [tex]\Omega r^2 = constant = k[/tex](fluid parcels slowly spiraling towards origin while conserving angular momentum)
c) [tex]\Omega^2 r = G*M/r^2[/tex] (velocity distribution inside accretion disk in black hole or neutron star)
So, I chose to ignore the bogus part (1) and solve in cyl coord where [tex]v = (u_r, u_{\theta}, u_z)[/tex]. For all three cases I assumed that [tex]u_z = 0[/tex] (given) and [tex]u_r = 0[/tex] ("flow is the form a circular 'swirl' about the origin in the x-y plane"). (If [tex]u_r[/tex] is not zero, I haven't a clue as to how to come up with a u_r...)
Then, blithely proceeding:
* In cyl. coor, [tex]u_{\theta} = r * \Omega(r)[/tex], where [tex]\Omega(r) =[/tex] angular velocity.
* Then, vorticity [tex]w = \nabla \times v[/tex] is [tex]w_z[/tex] only and reduces to
[tex]w_z = \frac {1} {r} \frac {d} {dr} (r * u_{\theta}) = \frac {1} {r} \frac {d} {dr}(r * r * \Omega(r))[/tex]
Using this approach I get,
a) [tex]\Omega(r) = q/r[/tex] gives [tex]w = \frac {1} {r} \frac {d} {dr}(r * r * q/r) = \frac {1} {r} \frac {d} {dr}(r*q) = q/r[/tex]
b) [tex]\Omega r^2 = k \Rightarrow \Omega(r) = k/ r^2 \Rightarrow <br /> w = \frac {1} {r} \frac {d} {dr}(r * r * k / r^2) = \frac {1} {r} \frac {d} {dr}(k) = 0[/tex]
c) [tex]\Omega^2 r = G*M/r^2 \Rightarrow \Omega(r) = \frac {k_2} {r^{3/2}} \Rightarrow w = \frac {1} {r} \frac {d} {dr}(r * r * \frac {k_2} {r^{3/2}}) = \frac {k_2} {r} \frac {d} {dr}(r^{1/2}) = \frac {k_2} {2} r^{-3/2}[/tex]
Am I even close here?
Confused in Seattle,
/catboy
I'm not checked your solution, but the statement of your book (see the quoting) is wrong. That velocities haven't got dimensions of speed (they have dimensions of angular velocity). So I wouldn't pay much attention at that solution the book provides you.
Desconfusing in Madrid. :biggrin:
  • · Replies 59 ·
  • · Replies 20 ·
