Bifundamental wrt two gravities
  • Context: Graduate
  • Thread starter Thread starter atyy
The discussion centers around the concept of a "bifundamental" scalar field in the context of two gravities as described in the paper by Nickel and Son. Participants explore the implications of this idea within the framework of holographic duality, gauge theories, and the behavior of gravity at boundaries in AdS/CFT scenarios.
  • Some participants explain that the scalar field is considered "bifundamental" with respect to two gravities, indicating a relationship between the scalar field and the metrics of the two gravitational theories.
  • Others discuss the implications of this bifundamental nature for understanding correlation functions and the mapping of fields between boundaries in the context of holographic duality.
  • A participant raises questions about the presence of gravity at the boundary, noting a common understanding that boundaries in AdS/CFT scenarios typically do not exhibit gravity.
  • Responses clarify that gravity at the boundary is treated as a background field, while fluctuations occur on the cutoff surface, which must be accounted for in calculations.
  • Some participants suggest potential applications of the bifundamental concept, including connections to dS/dS correspondence and relationships between different dimensional gauge theories.
  • There is mention of the possibility of generalizing concepts like Evenbly's "branching MERA" in relation to the bifundamental framework.
Participants express varying levels of understanding regarding the implications of gravity at the boundary and the bifundamental nature of the scalar field. There is no consensus on the interpretation of gravity's role at the boundary, indicating an ongoing debate.
Some discussions reference specific papers and concepts, but there are unresolved questions regarding the assumptions made about gravity at the boundary and the nature of the scalar fields involved.
atyy
In http://arxiv.org/abs/1009.3094, Nickel and Son say "Hydrodynamics, therefore, is a theory of a Goldstone boson, bifundamental with respect to two gravities."
What does that mean?
This paper is an attempt to break down the correlation function producing machinery of holographic duality into its most basic pieces. They are trying to formalize the idea that the region deep in the bulk corresponds to the IR and to understand how to carry the data contained there to the boundary in order to compute correlation functions.
Figure 1 in that paper shows the basic setup. They first consider an external U(1) gauge field A. This A couples to a conserved current J which is dual to gauge field in the bulk B. At this point A is a 4d gauge field and B is a 5d gauge field. Now they introduce a new slice in the bulk and study the partition function of the bulk theory as a function of the boundary conditions at the asymptotic boundary and the cutoff. This is the middle bit between cutoff and boundary in Figure 2. These boundary conditions consist of the value of A at infinity and the value of B restricted to the cutoff surface which they call a. They also introduce a scalar field, a "goldstone boson", that couples to both A and a (both 4d gauge fields) with charges 1 and -1. In the usual parlance of gauge theory we would say that the scalar is a bifundamental of U(1)_A x U(1)_a. This terminology is often used for describing the matter content of non-Abelian gauge theories and is summarized in "moose diagrams" like Figure 1.
That is background information for your question.
Now they consider the case of gravity. As before, one has a boundary metric G, and boundary stress T, and a dual metric H. G is 4d and H is 5d. Again, introduce a bulk surface and study the bulk action as a function of boundary conditions at the boundary and the cutoff. H restricted to the cutoff surface is g, a 4d metric. There are also scalar fields that are "charged" under both metrics. In fact, these scalars are a mapping from the coordinates on one boundary to the coordinates on the other boundary. In the U(1) case above, the scalar field could be understood as taking a field charged under A, removing the A charge, and adding some a charge. The gravitational case is similar. The coordinate mapping takes things (in the simplest case just vectors) "charged" under G to things "charged" under g (or vice versa). So in some fairly precise sense the scalar field is "bifundamental with respect to two gravities" (fundamental because the vector is the smallest non-projective representation).
Hope this helps.
This all looks rather important!
I haven't read much about http://arxiv.org/abs/hep-th/0104005" .
First application that comes to mind: iteration of https://www.physicsforums.com/showthread.php?t=506476". The dS/dS correspondence somehow seems to be the reverse of this bigravity goldstone idea. Here, you have an AdS boundary, and further in, a horizon. In dS/dS, you have a cosmological horizon, and then further in, a special timelike hypersurface where the graviton becomes massive.
But either way, you're starting to turn holography into a modularized process. The bulk is divided into regions, and then you collapse a region onto its boundary. Leaping ahead, this reminds me very much of the role that volumes of polytopes play in the new motivic picture of amplitudes. It's quite logical to suppose that a "holographic cohomology" will provide the most general picture of this process.
Second application that comes to mind: understanding the relationship between 4d gauge theories and 6d strongly coupled theories. Here I link to a http://arxiv.org/abs/hep-ph/0207164" .)
Third idea that comes to mind: I wonder if Evenbly's "branching MERA" can be understood as a generalization of deconstruction.
Thanks for the background and explanation! I don't understand why there is gravity at the boundary. I thought the boundary in AdS/CFT scenarios had no gravity?
Gravity at the boundary has the status of a background field. It just corresponds to putting the cft on a non-fluctuating curved background.
However, gravity on the cutoff surface is fluctuating, so we must sum over it in principle. In Son et al's paper they use large N to approximate this sum via saddle point.
The same thing is true for the U(1) story. The boundary gauge field is a non-fluctuating background field.
Ok, thanks!
  • · Replies 0 ·
