What is the Relationship Between Heat Energy and Temperature?
The discussion revolves around the relationship between heat energy and temperature, specifically focusing on the heat energy per unit mass required to raise the temperature of a material. The original poster presents a mathematical statement involving an integral that contrasts with a simpler expression when specific heat is treated as a constant.
  • Participants explore the implications of specific heat being a function of both position and temperature, questioning the validity of the original integral. They discuss the need to integrate the change in energy with respect to temperature and consider different approaches to express the relationship mathematically.
There is an ongoing exploration of the mathematical formulation, with some participants suggesting different methods to approach the problem. Guidance has been offered regarding the use of differentials and integrals, and participants are actively engaging with each other's ideas without reaching a definitive conclusion.
Participants are navigating the complexities of the problem, particularly regarding the assumptions about specific heat and its dependence on temperature and position. The original poster expresses uncertainty about the clarity of their approach, indicating potential gaps in understanding.
tavrion
Show that the heat energy per unit mass necessary to raise the temperature of a thin slice of thickness [itex]\Delta[/itex]x from [itex]0^o{}[/itex] to [itex]u(x,t)[/itex] is not [itex]c(x)u(x,t)[/itex]. but instead [itex]\int_0^uc(x,\overline{u})d\overline{u}[/itex].
According to the text, the relationship between thermal energy and temperature is given by
[itex]e(x,t) = c(x)p(x)u(x,t)[/itex],
which states that the thermal energy per unit volume equals the thermal energy per unit mass per unit degree times the temperature time the mass density.
When the specific heat [itex]c(x)[/itex] is independent of temperature, the heat energy per unit mass is just [itex]c(x)u(x,t)[/itex].
The only hint really is that this is related to the area, from the solution. How can I go about this geometrically and/or algebraically?
Any help/pointers will be much appreciated. Thank you!
that integral doesn't make sense based on what you've posted, can you check it... c has changed to a function of x only or x and u (position and temperature)...?
so i think you do need to assume c = c(x,u), then try and find the change in energy de, for a small change in temp du and integrate.
Argh of course! Thank you very much! :approve:
I have used your advice and went about it in the following way:
For a small slice of thickness [itex]\Delta{x}[/itex] a small change in energy will be given by
[itex]de = c(x,u)du[/itex]
Dividing by [itex]du[/itex] I obtain [itex]e_{u} = c(x,u)[/itex].
From the Fundamental Theorem of Calculus, this really says that
[itex]e(x,t) = \int_0^uc(x,t)dt[/itex].
Am I correct in my thinking? It feels a bit messy somehow...
you can just start from differentials
[tex]de = c(x,u)du[/tex]
[tex]\delta e = \int_{e_0}^{e_f}d\bar{e} = \int_{0}^{u} c(x,\bar{u})d\bar{u}[/tex]
Your equation did not even occur to me but simplifies it a lot. Thank you very much for your help. I can now get some sleep again :-)
