Eigenvalues of a matrix B= f(A) given eigenvalues of A
The discussion revolves around finding the eigenvalues and eigenvectors of the matrix B = exp(3A) + 5I, given the eigenvalues and eigenvectors of a 3x3 matrix A. Participants explore the relationship between the eigenvalues of A and those of B, particularly through the use of matrix functions.
  • The original poster attempts to relate the eigenvalues of B to those of A through the expression for B and the properties of matrix exponentiation. Some participants question the reasoning behind the application of the eigenvalue relationship and the use of power series expansions.
Some participants provide supportive feedback on the original poster's reasoning, while others introduce theorems related to matrix functions and eigenvalues, suggesting a deeper exploration of the topic. There is an ongoing exchange of ideas regarding the notation and theorems presented, indicating a productive dialogue without a clear consensus yet.
Participants note the importance of distinct eigenvalues in the context of the theorems discussed, and there are references to specific mathematical texts that may provide further insight into the concepts being explored.
L-x
Find the eigenvalues/vectors of A. (I can do this bit :P, A is a 3x3 matrix)
What are the eigenvalues and eigenvectors of the matrix B = exp(3A) + 5I, where I is
the identity matrix?
I have (correctly) found that A has eigenvectors and corresponding eigenvalues such that
A|1>=|1>, A|2>=2|2>, A|4>=4|4>.
|1>=(1,1,1), |2>=(1,-1,0), |4>=(1,1,-2) though i don't actually think you need this.
as B can be expanded in a power series of A, and A commutes with the identity (obiously)
[B,A]=0
=> |1>, |2>, |4> are eigenvectors of B
I am not confident in the reasoning that follows, does it seem correct?
exp(3A)|j>=e^(3j)|j>
5I|j>=5|j>
j=1,2,4
=> the eigenvectors of B are |1>, |2>, |4> with respective eigenvalues (e^3 +5), (e^6 +5), (e^12 +5)
Does this seem correct? Thanks in advance for your help.
Hi L-x! :smile:
Seems ok!
There is a theorem in matrix analysis that for an nxn matrix A having n distinct eigenvalues (lambda_1, ..., lambda_n), and for any analytic function f(x) = sum_{n=0}^infinity c_n *x^n, the function f(A) =def= c_0*Identity + sum_{n=1}^infinity c_n * A^n has the form
f(A) = sum_{j=1}^{n} E_j * f(lamba_j), where E_1,...,E_n are nxn matrices that do not depend on the form of f(.) . Furthermore, if v1, v2,..., vn are eigenvectors for the n eigenvalues, we have E_i*v*j = 0 for i =/= j. So, in your case, taking f(x) = x^0 we have Identity = 1^0*E1 + 2^0*E2 + 3^0*E3 = E1+E2+E3, taking f(x) = x gives A = E1 + 2E2 + 3E3, and taking f(x) = x^2 gives A^2 = E1 + 4*E2 + 9*E3. So, you can determine E1, E2 and E3. Then, of course, for f(x) = exp(3x) + 5 we have f(A) = E1*(exp(3)+5) + E2*(exp(6)+5) + E3*(exp(9)+5). Thus, f(A)*v1 = (exp(3)+5)*v1, etc. (Note that you do not need to a actually find E1, E2 and E3 to answer the question.)
RGV
RGV
This looks interesting but I'm having quite a lot of trouble following your notation. Do you know the name of the theorem so i could look it up perhaps?
Thanks for the help.
The old books “Matrices”, by Gantmacher, or the book “Theory of Matrices”, by P. Lancaster (Academic Press, 1969) have these results. I am sure there are numerous more modern treatments, but those two are the ones I have on my bookshelf.
Anyway, below I will give a short proof for the case of a 3 x 3 matrix A having 3 distinct, non-zero real eigenvalues r1, r2 and r3. The same form of proof goes through for a general nxn matrix with n distinct, real, nonzero eigenvalues. The basic result is the same, but with a somewhat different proof, if some of the eigenvalues are complex or some are zero. Distinctness remains important; without it we need to invoke Jordan Canonical forms, and f(A) can involve not only f(r) for eigenvalue r, but also f’(r). f’’’(r), etc., depending on the multiplicity of r and the form of its Jordan block(s).
So, let ui and vi be the left and right-eigenvectors of A for eigenvalue ri, chosen so that ui*vi = 1. Note that for rj different from ri we have ui*vj = 0; see, eg,
http://answers.yahoo.com/question/index?qid=20100729070957AAlQuHF . Note that the vi form a basis for the whole space. Now let Ei = vi*ui for all i; we have that Ei is a 3x3 matrix because it is of the form column x row in that order. The orthogonality results imply that Ei*Ei = Ei and Ei*Ej = 0 if i is different from j. Letting B = sum ri*Ei, we have that B*vi = ri*vi for all i, hence (B-A)*vi = 0 for all vi, hence (B-A)w = 0 for all vectors w, because all such w have the form sum ci*vi . Thus, B = A, so we have shown that A = sum ri*Ei. Now look at C = E1+E2+E3. We have C*vi = vi for all i, so C*w = w for all vectors w. That is, C = Identity matrix I. Now we are almost done.
Look at any polynomial p(x) = c0 + c1*x + c2*x^2 + … + cm*x^m, and _define_ p(A) = c0*I + c1*A + c2*A^2 + … + cm*A^m. We have A^2 = sum ri^2 * Ei*Ei + sum_{i < j}ri*rj Ei*Ej + sum_{j < i} rj*ri*Ej*Ei = sum ri^2 * Ei + 0 + 0. Similarly, A^3 = sum ri^3*Ei, etc. Finally, we have I = sum Ei = sum ri^0 * Ei (this is where having all ri nonzero comes in!), so we have that p(A) = c0*A^0 + c1*A^1 + … + cm*A^m is of the form p(A) = sum p(ri)*Ei. If f(x) is an analytic function whose radius of convergence includes the largest |eigenvalue|, then the same type of argument goes through, by taking some limits. The result is f(A) = sum f(ri)*Ei.
This stuff is typically used in solving constant-coefficient couples ODEs, because if x is a vector and A is a constant matrix, the DE system dx/dt = Ax has solution x(t) = exp(A*t)*x(0), so we need to know how to compute matrix exponentials.
RGV
How about just changing to the basis given by the eigenvectors (they should be linearly independent since there are 3 distinct eigenvalues). then in this basis A is just diagonal so the exponent is just the diagonal matrix with the exponents on the diagonal (so the diagonal entries exponentiated on the diagonal).
  • · Replies 19 ·
