High energy electron/electron collisions
Research into high energy electron/electron collisions is currently limited, with significant proposals like the International Linear Collider (ILC) and the Compact Linear Collider (CLIC) on hold pending results from the Large Hadron Collider (LHC). The last collider of this type was the Large Electron Positron (LEP) collider at CERN, which operated at a maximum energy of 100 GeV before its decommissioning in 2000. High energy electron collisions offer advantages in precision over proton collisions, as they allow for more accurately determined energy levels. However, the challenge of accelerating electrons due to synchrotron radiation necessitates the use of linear colliders.
  • Understanding of particle physics principles
  • Familiarity with collider types, specifically linear vs. circular colliders
  • Knowledge of synchrotron radiation effects on particle acceleration
  • Basic grasp of quantum mechanics and energy-matter interactions
  • Research the design and physics behind the International Linear Collider (ILC)
  • Explore the Compact Linear Collider (CLIC) and its proposed energy capabilities
  • Study the implications of synchrotron radiation in electron acceleration
  • Investigate the findings from the Large Hadron Collider (LHC) related to Higgs boson studies
Particle physicists, researchers in high-energy physics, and students interested in advanced collider technologies and their implications in fundamental physics research.
Dadface
Can anybody tell me if any research is currently being carried out,or planned,to investigate further high energy electron/electron collisions?If so what sort of information may such research reveal?The only thing I can think of is that any research may be able to test Coulombs law down to shorter length limits.Thank you.
The last collider like this was the LEP, "Large Electron Positron" collider, at CERN. It had a maximum energy of 100 GeV per beam, and was decommisioned in 2000 to make room for the Large Hadron Collider, which now occupies the same tunnel.
There are proposals for an ILC, "International Linear Collider", which would have an energy of 500 GeV or possibly 1 TeV. Also CLIC, "Compact Linear Collider", which might have a still higher energy in the 3 to 5 TeV range. Mainly, all such plans are on hold until results from the LHC indicate whether building such a machine would be justified.
Colliding electrons is not so much different from colliding protons. In both cases you get debris consisting of "everything", although in different proportions. The big advantage is accuracy. High energy proton collisions are in reality collisions between two quarks, and since quarks oscillate violently inside their protons, the energy of the collision is not sharply determined. When colliding electrons you know the energy.
The disadvantage is that it's harder to accelerate electrons, since they radiate so much synchrotron radiation. You need to use linear colliders rather than circular colliders to reduce this.
All the things being studied by the LHC, including Higgs, could be studied further by these machines.
Thank you Bill K,
I'm sort of familiar with collisions of the type particle/antiparticle,proton /proton etc but not electron /electron (or positron/positron).Should these particles approach head on at speed and in the absence of forces(apart from the electrostatic repulsion between them) then there is an event involving the conversion between KE and PE and where the particles reach a point of closest approach and then retreat from each other.Is it so that at high enough energies the event is more involved including,for example,the creation of other particles.If so it would be great if you could give me a reference where I could read up on this.
Thank you.
  • · Replies 0 ·
  • · Replies 57 ·
16K
