Can Matrix Dimensions Vary Within the Same Vector Space Transformation?
The discussion clarifies that in a finite dimensional inner product space V = M_{n \times n}(\mathbb{R}), the matrix representation of a linear operator T, denoted as A = [T]_{\beta}, is indeed an (n² x n²)-matrix. This is because T maps from V to itself, where the basis consists of n² (n x n)-matrices. The confusion arises from misinterpreting the dimensions of the matrices involved; A cannot be an (n x n)-matrix as it does not align with the dimensionality of the vector space. The equality [I_V]_{\beta} = I_N holds true as both sides represent (n² x n²)-matrices.
  • Understanding of finite dimensional inner product spaces
  • Familiarity with linear operators and their matrix representations
  • Knowledge of tensorial notation in linear algebra
  • Basic concepts of vector spaces and dimensions
  • Study the properties of linear operators in finite dimensional spaces
  • Learn about the relationship between linear transformations and their matrix representations
  • Explore tensorial notation and its applications in linear algebra
  • Investigate the implications of dimensionality in vector space transformations
Mathematicians, physics students, and anyone studying linear algebra, particularly those interested in the properties of linear operators and transformations within vector spaces.
AKG
If I have a finite dimensional inner product space [itex]V = M_{n \times n}(\mathbb{R})[/itex], then one basis of V is the set of n² (n x n)-matrices, [itex]\beta = \{E_1, \dots , E_{n^2}\}[/itex] where [itex]E_i[/itex] has a 1 in the [itex]i^{th}[/itex] position, and zeroes elsewhere (and by [itex]i^{th}[/itex] position, I mean that the first position is the top-left, the second position is just to the right of the top-left, and the last position is the bottom-right). Since these matrices are linearly independent and span V, they certainly form a basis, and since there are n² of them, dim(V) = n². Therefore, if I have some linear operator T on V, then [itex]A = [T]_{\beta}[/itex] is an (n² x n²)-matrix, right? However, if v is some element of V, then T(v) = Av, but Av is not even possible, since it involves multiplying two square matrices of different dimension. Now, if I had made a mistake earlier, then maybe A is supposed to be an (n x n)-matrix. But that doesn't seem right.
My textbook proves:
If V is an N-dimensional vector space with an ordered basis [itex]\beta[/itex], then [itex][I_V]_{\beta} = I_N[/itex], where [itex]I_V[/itex] is the identity operator on V. Now, in our case, N = n², but if I was wrong before, and in the previous example, A should have been an (n x n)-matrix, then the equality above essentially states that an (n x n)-matrix is equal to an (n² x n²)-matrix. Where have I (or my book) made a mistake?
I´m not completely sure if I got your question but maybe I´m guessing right where your problems lie:
Assume a linear operator O over the R^n. It can be written in the form of O(a) = Ma for any vector a. M is an n x n matrix here. Certainly M and a don´t have the same "dimension" (dunno the proper english term; probably "level"). And you probably wouldn´t feel that this is not going to work, because you know how to interpret the equation.
In tensorial notation using the components of the vector a above is written like this:
[tex]T(a^\nu) = \sum_{\nu=1} ^n M^\mu _{\, \nu} a^\nu = b^\mu[/tex]
The last "=" was put into show that the result b is a vector of R^n again.
Rewriting your "T(v) = Av" in tensorial terms it would be:
[tex]T(v^{\mu \nu}) = \sum_{\mu=1} ^n \sum _{\nu=1} ^n A^{\alpha \beta}_{\, \, \, \mu \nu} v^{\mu \nu} = b^{\alpha \beta}[/tex]
So the equation is defined and the result is an element of V.
Sidenotes:
- Av = A*v is never possible unless you define what it´s supposed to be. Tensorial notation like above does this.
- I didn´t understand what your textbook sais because I neither know the notation nor do I know what [tex]I_N[/tex] is. So it´s well possible that I completely missed your question.
In this case, the mistake lies in assuming that the linear operator T maps from V to V, when in fact it maps from V to itself. This means that the matrix A is not an (n x n)-matrix, but rather an (n² x n²)-matrix, as stated in the original content. The confusion may arise from thinking of T as a transformation between different vector spaces, but in this case, it is a transformation within the same vector space V. Therefore, the dimensions of the matrices involved will also be the same.
To understand this better, consider the example of a linear transformation T: \mathbb{R}^2 \rightarrow \mathbb{R}^2 given by T(x,y) = (2x,3y). Here, the matrix representation of T with respect to the standard basis is a 2x2 matrix. However, if we consider the same transformation T as a mapping from \mathbb{R}^4 to \mathbb{R}^4, then the matrix representation will be a 4x4 matrix. The dimensions of the matrices change depending on the vector space they are representing the transformation in.
In the case of a linear operator T on V, the matrix representation A = [T]_{\beta} is an (n² x n²)-matrix because T maps from V to itself, and the basis \beta is of n² (n x n)-matrices. This is consistent with the dimension of V being n². The equality [I_V]_{\beta} = I_N also makes sense, as both sides are (n² x n²)-matrices.
In conclusion, there is no mistake in the original content or in the textbook. The confusion may arise from not differentiating between a linear operator and a linear transformation, and the dimensions of matrices representing them.
  • · Replies 21 ·
  • · Replies 25 ·
