Can centripetal acceleration be called centripetal? jerk?
The discussion revolves around the concept of centripetal acceleration and its relationship to the term "jerk." Participants explore whether the change in centripetal acceleration, particularly in the context of uniform circular motion, can be classified as jerk, which is defined as the rate of change of acceleration. The conversation includes theoretical considerations, mathematical expressions, and differing interpretations of terminology.
  • Some participants question whether the acceleration changing from one value to another in centripetal motion can be considered jerk, as jerk is typically defined as the rate of change of acceleration.
  • Others argue that uniform circular motion does exhibit jerk due to the non-zero third time derivative of position, although the term's application is debated.
  • One participant suggests that jerk is usually associated with changes in magnitude of acceleration rather than direction, noting that in uniform circular motion, the magnitude of centripetal acceleration remains constant.
  • A mathematical expression for jerk is proposed, relating it to the change in centripetal and tangential acceleration, with a derivation provided that leads to the conclusion of a specific formula.
  • Some participants express confusion over the application of the term "jerk" in the context of circular motion, particularly regarding inertial effects and the reference frame of the body in motion.
  • There is a discussion about the implications of changing forces and the resulting effects on perceived motion within a rotating frame, with examples drawn from amusement rides.
Participants do not reach a consensus on whether the term "jerk" can be appropriately applied to centripetal acceleration in uniform circular motion. Multiple competing views remain regarding the definitions and implications of jerk in this context.
Limitations include varying interpretations of the term "jerk," dependence on specific definitions of motion, and the unresolved nature of the mathematical derivations presented by participants.
Alpharup
Well I am now confused about centripetal acceleration. I have heard sometime ago that the change of acceleration is jerk. Let a body in centripetal acceleration change its velocity from 'v' to 'v1' in time 't'. The formula for centripetal acceleration is v^2/r. Let this acceleration be 'a'. Can the acceleration which originates from the point v1 be considered as v1^2/r? If it can be considered let this acceleration be 'a1'. Since the acceleration changes from 'a' to 'a1' in time 't', can the rate be called jerk? is my argument correct?
I don't quite understand what you're saying here. In any case, since jerk is the rate of change of acceleration (a vector), even uniform circular motion displays jerk.
As you point out, the third time derivative of position for an object experiencing uniform circular motion is non-zero. Whether this should be called "jerk" is a matter of terminology. I don't know how that term is supposed to be used - it is rarely used by physicists. But there is nothing "jerky" about uniform circular motion.
If the term "jerk" was intended to refer to the inertial effects within a body arising from a change in applied force, it would be confusing to apply it to uniform circular motion, which gives rise to no such effects.
AM
I think you're right. I've never seen it applied in that fashion. (And certainly from a rotating frame of reference there'd be no changing acceleration.) I've only seen jerk used to describe linear motion. (By engineers, not physicists.)
Centripetal acceleration in uniform circular motion only changes in direction, not in magnitude. From my experience in engineering, "jerk" is the change in acceleration per unit time, but it usually only applies to the change in magnitude, not the change in direction. If the object were speeding up or slowing down, you could describe that as "jerk". However, I've only heard the term used rarely and only where sudden changes in acceleration become important, like in cam design.
wellve i have found an expression for this jerk. please correct me if iam wrong. for a body to revolve in uniform circular motion, you need a force which is called centripetal force.if this centripetal force is constant the body revolves with constant speed . inorder to induce tangential acceleration to the body in circular motion, you need to increase the force at a constant rate. let us assume that the body starts from rest and moves with constant speed for a time 'x'. here the initial centripetal force is constant. let the angular velocity of the particle be 'w' and linear velocity be 'v' for this constant centripetal force. after this time x, you increase your force so as to induce tangential acceleration 'A'. the resultant of the centripetal and tangential acceleration can be found out. the body also experiences a jerk[J] which is directed towards the centre. the expression is
J=2wA
the proof is very simple as i had said in my first post ''Let a body in centripetal acceleration change its velocity from 'v' to 'v1' in time 't'. The formula for centripetal acceleration is v^2/r. Let this acceleration be 'a'. Can the acceleration which originates from the point v1 be considered as v1^2/r? If it can be considered let this acceleration be 'a1'. Since the acceleration changes from 'a' to 'a1' in time 't', can the rate be called jerk?'' let us use these variables which i used earlier but with some change. let the change in velocity of the body be very small ie.. v1~=v. let the time for of change also be very small ie.. t tends to '0'. i had used a little calculus to prove it.
now J=a1-a/t.
by simplification and by substituting the values of acceleration
we get
J= v1^2 - v^2 / rt
= [v1+v]*[v1-v]/rt {using algebra equation}
= [v1+v]*A/r {since the time to change is small, rate of change of velocity gives tangential acceleration}
= 2vA/r {since velocity change is small, we can substitute v1=v}
= 2wA {since v=rw or linear velocity = [angular velocity]*[radius]}
this even satisfies cross product of vectors where direction of jerk can be found that it is towards the centre
I think I have proved.
You are apparently assuming that the body in circular motion is also spinning at the same rate, so the centripetal force vector is constant in the reference frame of the body. But this is not always the case. If you are in a cabin that goes in circles, but keeps a fixed orientation, you will be "jerked around" a lot.
You are quite right. That is part of the principle behind the Tilt-o-Whirl and other amusement rides. In that case, however, you would not be traveling in uniform circular motion.
AM
Why not? Every part of of the cabin travels in uniform circular motion, just around different centers. I would be "jerked around" in the cabin, just like in a car that truns left - right - left. The word "jerk" makes perfect sense here.
well is my expresion, right?
It does indeed make sense. My only point is that it is not in uniform circular motion. The OP asked whether uniform circular motion (ie where [itex]\vec{a} = -\hat r v^2/r[/itex]) could be termed "jerk".
The centre of mass of the cabin moves in uniform circular motion. But if you plot the motion of a person in one of the outer corners you will see that the radial displacement from the centre of rotation is constantly changing in both magnitude and direction and the angular speed varies as well.
AM
  • · Replies 24 ·
  • · Replies 37 ·
