FORTRAN 90 command line arrgument
  • Context: Fortran
  • Thread starter Thread starter nikkinath
    Fortran Line
The discussion focuses on executing a FORTRAN 90 program that requires three command line arguments: a text file and two variables. Users seek to automate the execution of this program multiple times with varying arguments, specifically using nested loops to iterate through values for the variables. The solution involves using the getarg() subroutine to retrieve command line arguments and suggests writing a shell script to handle the looping and execution of the FORTRAN executable.
  • Understanding of FORTRAN 90 syntax and structure
  • Familiarity with command line operations and arguments
  • Basic knowledge of shell scripting (e.g., Bash)
  • Experience with nested loops in programming
  • Learn how to use the getarg() subroutine in FORTRAN 90
  • Research shell scripting techniques for executing programs with arguments
  • Explore FORTRAN 90 array handling for managing multiple variable inputs
  • Investigate how to redirect output in shell scripts to consolidate results
FORTRAN programmers, researchers automating simulations, and developers looking to integrate command line arguments into their FORTRAN applications.
nikkinath
Hi All,
I am very new to FORTRAN Programming. The problem is related to commandline argument. i have a executable program which take 3 command line argument as an input. one is text file and two is variable. I want to write a script were i can execute this script and save in different file and should be able to change the arguments. for example;
./exe1 input.txt x x[j] > output.txt
i=j=1 ... 10
Any help or suggestion will be appreciated. Please let me know if any other information is neede.
Thank you
Technology news on Phys.org
nikkinath said:
Hi All,
i=j=1 ... 10
Thank you
According to this web page, you can use the getarg() subroutine to get the i-th command line argument.
Code:
          PROGRAM test_getarg
            INTEGER :: i
            CHARACTER(len=32) :: arg
            DO i = 1, iargc()
              CALL getarg(i, arg)
              WRITE (*,*) arg
            END DO
          END PROGRAM
Your description of what you're trying to do is not very clear, particularly what you need to do with the two variables on the command line. Can be give a clearer description?
Thank you so much for your help and sorry for confusion.
beside input.txt file i have one more input file which have 10 variable (x1,x2...x10) and i would like to make a script which read nested loop to read and compute x1 and x1 and for next iteration it should consider x1 and x2.. and so on such that this script will give me n*n metrix..
and save this ouput in new output.txt file ..
if still some confusion please let me know...
Thank you for your advise
Why do you need two input files?
The input file almost certainly doesn't contain variables - it contains numbers. Variables are what your program (which is NOT a script) uses to store numbers.
What do you mean "read and compute x1 and x1?"
How will your program "consider" x1 and x2?
I still don't know what you're trying to do.
sorry for the confusion again as i told you before very new to FORTRAN I need to run this for my research.. so thought ask for help...
I haven't made this ./exe program i am just using it and to execute this ./exe we need 3 arguments one is input.txt file and other two are variables such as X and Y..
but i want to run this ./exe for more than 10 times .. if i want i can do it manually by entering all the values of X and Y one by one... but i want to know if there is any way i can write a program such that itself read another file which contains values of X and Y and execute ./exe
i know how to do this in R or C ... but my less knowledge in Fortran is giving me hard time.
if still not clear than let me put it in this way
do i till 10
do j till 10
./exe input.txt x x[j] >> output.txt !but i want to amend all the output in one file
end do
end do
Why don't you write the code you want in C, since you're more familiar with that than you are with Fortran?
If the fortran exe file is already compiled and all you want to do is run it a few times, what you need to do is write a script for the shell you are accustom to run the fortran, in the first place...
so, if you use a terminal with bash, just write a script that takes two arguments (names of the two files, the one input file and the one with the x's)...then, make the loop at the bash level and execute the fortran program from there.
  • · Replies 17 ·
