What is the difference between special and general theory ?
The discussion centers on the differences between the special and general theories of relativity, exploring their concepts, implications, and the foundational aspects of each theory. Participants express varying levels of understanding and seek clarification on technical terms and principles related to both theories.
  • Homework-related
  • Some participants note that special relativity deals with a flat, Lorentzian geometry of spacetime without gravity, while general relativity incorporates gravity and describes a curved spacetime.
  • One participant suggests that general relativity is more complex than special relativity, leading them to focus on the latter first.
  • There is a discussion about how mass generates gravity and how this affects the curvature of spacetime, with some participants seeking further explanations on these concepts.
  • Several participants mention the importance of foundational knowledge in special relativity before tackling general relativity, with recommendations for books and resources to aid learning.
  • Some participants express a desire for simpler explanations and resources, indicating varying levels of familiarity with the subject matter.
Participants generally agree on the foundational differences between the two theories and the importance of starting with special relativity. However, there are varying opinions on the complexity of general relativity and the best approach to learning about these theories, indicating that the discussion remains unresolved in terms of specific learning paths and conceptual clarity.
Some participants express uncertainty about technical terms such as "Lorentzian geometry," "globally flat," and "locally flat," highlighting the need for definitions and clarifications. The discussion also reflects a range of mathematical backgrounds among participants, which may influence their understanding of the theories.
This discussion may be useful for individuals interested in the foundational concepts of relativity, those seeking clarification on the differences between special and general relativity, and learners looking for resources to aid their understanding of these theories.
sciboudy
what is the difference between general theory and special theory of relativity :redface:?
The Einstein Field Equation.
can you Explain more ? i need to learn
This may be too technical of an answer,but in special relativity, the geometry of space-time is Lorentzian and globally flat.
In general relativity, the geometry of space-time is still Lorentzian, but it's no longer globally flat. The geometry of space-time is locally flat if you consider a small enough region, just as the surface of the Earth is locally flat (within some specified accuracy) if one considers a small enough piece of land. "Locally flat" doesn't mean the curvature dissapears, it just means that you can ignore it for practical purposes like surveying.
GR also has Einstein's field equations, which relate the curvature of space-time to the matter and energy present.
If you need or want a definition of "Lorentzian" geometry, just ask, though it might be helpful to have some idea of the level at which you want the answer.
really i need definition of lorentzian geometry and
what is the meaning of globally and locally because I'm not good at English
The special theory is a theory without gravity.
The general theory of relativity is a theory of gravity (and I have no idea why it is called "general relativity" instead of "Einstein's theory of gravity").
so general theory discuses the relation between space time and gravity
and special discuses the space time relation
so G theory more difficult than special
so i will focus special
The general theory simply says spacetime is gravity. Since mass generates gravity, gravity is changed by moving masses, which means that spacetime is curved.
Yes, it's good to start with the special theory. There spacetime is flat and unchanging, since there is no gravity.
before i start in spatial Explain how mass generates gravity ? how are you Concluded that mean
spacetime curved by moving masses?
Gravity is the force of attraction between masses. We think of a mass generating the gravitational field, which acts on another mass, attracting it to the first mass.
Now, what do we mean by spacetime? We mean something that we measure by rulers and clocks. If our ruler has mass, it will be attracted by other masses, and will be bent, so spacetime will appear curved in the presence of gravity.
good i think i will begin by special theory ? although i think general theory is more interesting
:cool:
:cool:
Yes. Definitely start with the special theory. It is a bad idea to start with the general theory. Mastering the special theory is the best way to start understanding the general theory:)
i heard that michlson experiment helps einstein to begin in the theory of special
what is this Experiment ? and HOw it helped him ?
This is the stage where you really want to get a book. You're not going to be able to learn SR by asking people questions on web forums. Some special relativity books that I like are (from easiest to hardest):
Takeuchi, An Illustrated Guide to Relativity
Mermin, It's About Time: Understanding Einstein's Relativity
Taylor and Wheeler, Spacetime Physics
okay i need easy book or some books
and I love discuses with people now i thin k they will help me ..:smile:
Well, yes, folks here WILL help you but I think Ben's point in saying that now is the time you need a book is that by JUST asking questions here, you will jump around too much. Get a book and read the whole thing through so that you get ALL of the aspects.
As you are reading, if you have questions then of course it is a good idea to ask them here.
Good luck.
okay thank can you give link for simple book of relativity special ...:smile::redface:
I suggest that you look up the books Ben listed on-line (Amazon will probably have reviews of them) and see if one of them would be right for your level of understanding of math. Doing that will lead you to other titles that you might want to explore to see if they are right for you.
i will do when i finish my Exams i will search for find good book
thank you :smile:
Usually, I need many, many books, since one book will explain somethings well and other things not so well (at least for my background). So it's good to buy maybe one or two cheap books, but otherwise visit a good library, or have some free stuff on the web to download, otherwise it'll be pretty expensive. Here are some things from the web, ordered roughly according to difficulty, though there's no reason not to jump around and cross-check that they all say the same thing. Tatsu Tekeuchi's and Michael Fowler's materials are probably the ones to sit down with and work through carefully.
http://www.einstein-online.info/elementary
http://www.phy.syr.edu/courses/modules/LIGHTCONE/
http://www.phys.vt.edu/~takeuchi/relativity/
http://galileo.phys.virginia.edu/classes/252/
http://people.maths.ox.ac.uk/nwoodh/sr/index.html
http://www.damtp.cam.ac.uk/research/gr/members/gibbons/gwgPartI_SpecialRelativity2010.pdf
http://ocw.mit.edu/courses/physics/8-033-relativity-fall-2006/lecture-notes/
http://www.bartleby.com/173/
http://www.fourmilab.ch/etexts/einstein/specrel/www/
thank you very much very good webs :smile:
Just for completeness, it doesn't look like anyone actually defined the term Lorentzian (in reference to a manifold) for you? Essentially, it means that the metric has a signature (- + + +) or (+ - - -) if you like. The crucial point is that it is a (3,1) spacetime, as opposed to something like (- - + +) or (+ + - -) which would be a (2,2) spacetime. When we break the space/time symmetry, we can identify a (3,1) spacetime by saying there are 3 spatial dimensions and 1 time dimension, which is, for practicality, the definition of a Lorentzian spacetime. In contrast, a (2,2) spacetime would have two time-like dimensions and two space-like dimensions.
thank you very much
  • · Replies 37 ·
  • · Replies 19 ·
