Solving Schrodinger Eq. w/ Crank Nicolson Method
  • Thread starter Thread starter WiFO215
    Crank Method
The discussion focuses on solving the Schrödinger equation using the Crank-Nicolson method and the tridiagonal matrix algorithm. The user is encountering issues with their implementation in Python, specifically with boundary conditions, indexing, and convergence of the solution. Suggestions provided include verifying boundary conditions, checking array indexing, considering alternative algorithms like LU decomposition, and debugging the code to track variable values.
  • Understanding of the Schrödinger equation and its numerical solutions
  • Familiarity with the Crank-Nicolson method for time-dependent problems
  • Knowledge of Python programming, particularly with NumPy for array manipulation
  • Experience with solving tridiagonal matrices using algorithms like the tridiagonal matrix algorithm
  • Review and validate boundary conditions in numerical simulations
  • Learn about LU decomposition as an alternative to the tridiagonal matrix algorithm
  • Explore debugging techniques in Python to track variable states
  • Investigate convergence criteria for numerical solutions of differential equations
Researchers, physicists, and computational scientists working on quantum mechanics simulations, particularly those implementing numerical methods for solving differential equations.
WiFO215
I have tried discretizing the Schrödinger equation using the crank nicolson method and then have tried to solve the resulting tri-diagonal matrix using the algorithm on Wikipedia.
http://en.wikipedia.org/wiki/Tridiagonal_matrix_algorithm
However, I am not getting the required result and cannot put my finger on it. Please help! I have attached the code below.
h is my space step and deltat is my time step. J = total number of space steps and K = total number of time steps
Code:
import numpy as np
#GIVEN DATA
h = 0.01
deltat = 0.001
J = 500
K = 500
phi_a = np.zeros(shape=(K,J), dtype = np.complex)
#BOUNDARY CONDITIONS#
for p in range(1,J-1):
   phi_a[0][p] = np.sin(np.pi*(p+1)/J)
a = np.ones(J, dtype=np.complex)/(4*h**2)
a[0], a[J-1] = 0,0
c = np.ones(J, dtype=np.complex)/(4*h**2)
c[0], c[J-1] = 0,0
def b(k):
   b = np.ones(J, dtype=np.complex)
      b[p] = (1j/(deltat)) - (1/(2*h**2))
   return(b)
def d(k):
   d = np.ones(J, dtype=np.complex)
   for p in range(1,J-2):
      d[p] = -(phi_a[k][p+1]/(4*h**2)) + (phi_a[k][p]*((1j/deltat) + 1/(2*h**2))) - (phi_a[k][p-1]/(4*h**2))
   d[0] = phi_a[k+1][0]
   d[J-1] = phi_a[k+1][J-1]
   return(d)
def tdms(a,c,k,s,b,d):
   b,d = b(k),d(k)
      c[p] = c[p]/(b[p] - c[p-1]*a[p])
   for p in range(J):
      d[p] = (d[p]-d[p-1]*a[p])/(b[p] - c[p-1]*a[p])
   for p in range(J-2,0,-1):
      s[k+1][p] = d[p] - c[p]*s[k+1][p+1]
   return
for k in range(0,K-1):
   tdms(a,c,k,phi_a,b,d)
anphi_a = open('test.txt','w')
for W in range(K):
   for Q in range(J-1):
      anphi_a.write(str(phi_a[W][Q]) + ', ')
   anphi_a.write(str(phi_a[W][J-1]) + '\n')
anphi_a.close()
This is written in Python, which is nearly pseudo-code, so most of you should be able to understand it. Please help!
Technology news on Phys.org
Hi there,
It's difficult to pinpoint the exact issue without more information, but here are a few suggestions that may help:
1. Double check your boundary conditions: Make sure they are correctly implemented and are consistent with the initial conditions.
2. Check your indexing: Make sure that you are using the correct indices when accessing and assigning values to arrays. A simple mistake in indexing can lead to unexpected results.
3. Consider using a different algorithm: The tridiagonal matrix algorithm is known to have stability issues for certain types of matrices. You may want to try using a different algorithm, such as the LU decomposition method, to solve the resulting matrix.
4. Check for convergence: Make sure that your solution is converging to a steady state. If it is not, then there may be a problem with your discretization or algorithm.
5. Debug your code: Use print statements or a debugger to track the values of your variables and make sure they are behaving as expected.
I hope these suggestions help. Good luck with your research!
  • · Replies 97 ·
10K
  • · Replies 17 ·
