Presuppositions of Standard Model?
The discussion centers on the presuppositions of the lambda-CDM model, particularly regarding the assumptions of spatial curvature and homogeneity in cosmological observations and calculations. Participants explore the implications of these assumptions on the model's predictions and the cosmic distance ladder, questioning whether the calculations are independent of the presupposition of a nearly flat universe.
  • Some participants assert that lambda-CDM models do not assume flatness, noting that various parameters are fitted to observational data, including the average density of baryonic matter.
  • Concerns are raised about whether the calculations of average densities from observational data would differ if the actual curvature were nonzero.
  • It is mentioned that while there is no assumption of zero curvature, certain observations may not be sensitive to curvature, leading to a common assumption of flatness in specific contexts.
  • Participants discuss the necessity of combining distant observations (like CMB) with nearby data (such as galaxy distributions) to constrain spatial curvature effectively, which is noted to be within about 1% of the total energy density of the universe.
Participants express differing views on the assumptions of the lambda-CDM model regarding spatial curvature and homogeneity. While some argue that the model does not presuppose flatness, others highlight that certain observations may lead to an implicit assumption of flatness. The discussion remains unresolved regarding the independence of model predictions from these presuppositions.
Limitations include the potential sensitivity of specific observations to curvature, the dependence of conclusions on the definitions of homogeneity and curvature, and the unresolved nature of how these assumptions affect the overall model predictions.
skippy1729
The lambda-CDM model predicts a nearly flat spatial curvature at scales larger than the the scale of homogeneity of the universe. The calculation of many of its parameters depend on the cosmic distance ladder which in turn depend on many observational techniques and statistical comparisons.
My questions are:
1. Have all of these myriad calculations been done in a manner which does not presuppose a nearly flat spatial universe?
2. Many of the observations leading to both the lambda-CDM model and the cosmic distance ladder are taken at distances far below the scale of homogeneity where no assumption of nearly flat curvature can be made (voids and filaments, for example). How has this been taken into consideration?
All of the predictions of these models are impressive but have they been shown to be independent of presuppositions of flatness?
Any references to this topic would be appreciated.
Skippy
Space news on Phys.org
ΛCDM models don't assume flatness. They have various parameters that are fit to the data, like the average density of baryonic matter, etc. One of the outputs is the average spatial curvature. This curvature just happens to be within error bars of zero based on current observations. They also don't assume perfect homogeneity. When you see graphs of the intensities of multipole moments, with fits to the model, that model is clearly not assuming homogeneity, because otherwise the intensities of all the multipole moments (beyond l=0) would be zero.
Wouldn't these average densities calculated from observational data be different if the actual curvature was nonzero?
Certainly. But there is no assumption that the curvature is zero, and there is no assumption that the average densities are such as to cause zero curvature.
Well, to be a bit pedantic, it isn't always assumed that the spatial curvature is zero. Often it is assumed to be zero, simply because the particular observation in question isn't sensitive to the curvature.
You only get a strong constraint on the curvature if you combine very far-away observations (e.g. CMB observations) with nearby observations (e.g. the distribution of galaxies, supernovae). And when we combine near data with far data, spatial curvature is constrained to be zero to within about 1% of the total energy density of the universe.
  • · Replies 34 ·
  • · Replies 22 ·
  • · Replies 27 ·
  • · Replies 26 ·
  • · Replies 37 ·
