Calculating the killing vector fields for axial symmetry
The discussion revolves around calculating the Killing vector fields (KVFs) for a galaxy modeled as a flat, axially symmetric disk. Participants explore the implications of axial symmetry and the challenges in systematically determining KVFs relevant to the metric of the galaxy.
  • One participant suggests that the Killing vector fields for a flat disk galaxy in cylindrical coordinates may include d(phi) and d(t), but questions the existence of other KVFs.
  • Another participant argues that d(z) cannot be a KVF due to the lack of symmetry under z-translation in a flat disk.
  • There is a discussion about the necessity of knowing non-trivial KVFs and the method of solving Killing's equations to find them, which is described as a complex process.
  • Some participants highlight that identifying trivial KVFs can be done by examining the metric for cyclic coordinates, but caution that this may not always reveal non-trivial KVFs.
  • Examples are discussed, such as Minkowski space, where certain KVFs are not immediately obvious, raising questions about the visibility of KVFs in different coordinate systems.
  • One participant requests examples of metrics where no KVFs are apparent, leading to further exploration of the relationship between cyclic coordinates and KVFs.
Participants express differing views on the existence and identification of KVFs in various metrics, with no consensus reached on the systematic approach to finding them or the implications of specific examples.
The discussion highlights the complexity of identifying KVFs and the potential for different coordinate systems to obscure their presence. There are unresolved questions regarding the relationship between symmetry and the visibility of KVFs in specific metrics.
tut_einstein
hi,
i need to calculate the killing vector fields for axial symmetry for a project so i can study the galaxy rotation curves. i am assuming the galaxy to be a flat disk, in addition to being axially symmetric. so i figured that the killing vector fields with respect to which the metric manifold on the galaxy will be unchanged are:
firstly, I'm using cylindrical coordinates: (t,r,z,phi) t=time (3+1)
d(phi) (for axial symmetry) where phi is the angle and
d(z) because the galaxy is a flat disk
i don't know if there will be other killing vector fields. the problem is that i don't know of a systematic way to calculate them.
thanks for the help!
dz won't be a KVF because a flat disc is not symmetric under z-translation: it would have to be an 'infinite cylinder' sort of object to satisfy this. Depending on what you're doing, dt might be a KVF though (if the setup is stationary).
Does your project require you to know the non - trivial killing vector fields (if any) for this metric? Do you have the metric in hand btw? You can tell the trivial (usually the important ones) killing fields just by looking at the metric and seeing which coordinates are cyclic but if you really need to find all of them the obvious, yet rather painful (depends on your metric but for 3 + 1 space - time this method is always painful by hand) is to solve killing's equations [itex]\bigtriangledown _{\alpha }\xi _{\beta } + \bigtriangledown _{\beta }\xi _{\alpha } = 0[/itex]. I don't think there is any simper way to find the non - trivial ones and I use the word simple loosely.
Things are more subtle than this. As an example, consider Minkowski space. In an inertial coordinate system, the four Killing vectors for spacetime translations are obvious, but the six equally important Killing vectors for rotations and boosts are not immediately obvious.
The metric may even be given in a form in which no Killing vectors are obvious. If the metric is given, then
It sounds, however, like tut_einstein might want to solve the inverse problem: given some symmetries (stationary, axisymmetric?), what des the metric look like? For a treatment of Killing vectors and stationary axisymmetric spacetimes, I recommend section 20.10 from An Introduction to general Relativity and Cosmology by Plebanski and Krasinski,
https://www.amazon.com/dp/052185623X/?tag=pfamazon01-20
Point taken. I guess since people automatically associate the isometries of the poincare group with minkowski space, looking at the respective metric wouldn't really be much of a help at all in such a case. I, however, have never seen a metric where not even one killing vector was immediately obvious from the presence of a cyclic coordinate (if not in one coordinate system then in some other). It would be awesome if you could give me an example of one or point me to one, thanks.
For any Killing vector field there always exists a cyclic coordinate system, and I didn't write anything that contradicts this. I wrote
Consider the Euclidean two-dimensional plane, which has three Killing vector field, two for translations and one for rotations. In elliptical coordinates, the Killing vectors are not obvious. The Euclidean metric expressed with respect to these coordinates is given by third equation of section Scale factors of
http://en.wikipedia.org/wiki/Elliptic_coordinate_system.
That this metric is for the Euclidean plane might not be obvious to someone (like me) who is unfamiliar with elliptical coordinates.
Oh no I wasn't saying you contradicted it, my apologies if it came out that way. I was just asking if there was some example where a metric could be put into any coordinate system without ever making at least one of the killing vector fields obvious.
Sorry, I didn't mean to sound so harsh.
(PS I haven't forgotten about particles in flat universes.)
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 73 ·
9K
