Laser Plasma: Basics & Theory Explained
  • Context: Undergrad
  • Thread starter Thread starter Nickolas
    Laser Plasma
Laser plasma refers to the interactions between intense laser radiation and plasma, a subject that has evolved since the invention of the laser. Key applications include Inertial Confinement Fusion, where terawatt laser pulses heat deuterium pellets to achieve fusion through compression. The interaction involves complex phenomena such as strong field inverse bremsstrahlung, stimulated Raman scattering (SRS), and stimulated Brillouin scattering (SBS), which can adversely affect the efficiency of energy absorption. Additionally, laser-induced breakdown leads to filamentation, allowing for efficient laser propagation in various applications like LIDAR.
  • Understanding of Inertial Confinement Fusion principles
  • Knowledge of laser physics, specifically terawatt laser technology
  • Familiarity with plasma physics and wave interactions
  • Concepts of nonlinear optics, including Kerr self-focusing
  • Research the principles of Inertial Confinement Fusion and its applications
  • Study the effects of stimulated Raman scattering (SRS) and stimulated Brillouin scattering (SBS) in laser-plasma interactions
  • Explore the mechanisms of laser-induced breakdown and its implications in various media
  • Learn about LIDAR technology and its use of filamentation in laser propagation
Researchers, physicists, and engineers interested in laser technology, plasma physics, and applications in fusion energy and remote sensing technologies.
Nickolas
what is the Baisc of laser plasma??
i just found about Laser-Plasma Interactions , but i would Know what is the theory of laser plasma and who was the first person studied this subjet??
could anyone help me!
Science news on Phys.org
Some of the ideas of laser plasma interaction date back to the invention of the laser itself. One of the more interesting applications is in so-called Inertial Confinement Fusion which is an alternative to magnetic confinement fusion. The basic idea is to use extremely intense laser radiation (terawatts) to heat small pellets filled with deuterium to extremely high temperatures such that the outer shell will ablate producing a rocket like effect thereby causing the fuel-containing interior to compress.
If the fuel is adequately compressed and heated then fusion can occur.
The laser interaction goes far beyond mere heating. For one thing the laser intensities are high enough to place the interaction into the strong field inverse bremmstrahlung (heating) regime which means heating is less efficient.
Fortunately, resonant coupling of the laser radiation with longitudinal electron plasma waves allows for efficient absorption of the laser light (linear wave conversion). Further, however, various types of stimulated scattering of laser light and other anomalous effect can occur at such elevated intensities including stimulated Raman (SRS) and Brilliouin (SBS)scattering (laser light interacting nonlinearly with electron plasma waves and ion acoustic waves respectively). Clearly, those will have adverse effects with the former (SRS) generating energetic electrons causing the core to heat prematurely making it more difficult to compress while the latter (SBS) can make the plasma reflect the laser light quite efficiently.
I've never heard of "laser plasma". Do you mean "laser generated plasma"?
Laser induced breakdown occurs when you "jiggle" an atom so hard that you end up ripping electrons out of their orbitals and inducing absorption in normally transparent media. The generated plasma alters the propagation characteristics of the laser beam - most notably it induces something called filamentation, which is a balancing act between nonlinear Kerr self-focusing and defocusing induced by the generated plasma, and results in light not spreading out as it propagates, rather traveling as a confined "filament" of light. LIDAR (The light version of Radar) utilises this phenomenon to deliver power to a distant target with minimal loss.
Claude.
  • · Replies 17 ·
