Why are observables represented by operators in Hilbert space?
  • Context: Graduate
  • Thread starter Thread starter Lostinthought
    Eigenvalues observables
The discussion centers around the representation of physical observables as operators in Hilbert space within the context of quantum mechanics. Participants explore the motivations behind this representation, the mathematical implications, and the historical development of these concepts.
  • One participant questions the motivation for representing physical observables as operators, seeking reasoning behind the assertion that their values correspond to eigenvalues.
  • Another participant states that this representation is a postulate of quantum mechanics and is not proven.
  • Some participants suggest that the motivation is mathematical, noting that physical observables can be viewed as matrix transformations, which inherently possess eigenvalues and eigenfunctions.
  • A participant provides an example of the Hamiltonian in one dimension as a matrix that acts on a state vector to yield observable energy values.
  • Discussion includes how various operations on state vectors can be represented as matrix relations, reinforcing the analogy to Hilbert space.
  • Historical context is introduced, with references to the development of quantum mechanics through matrix mechanics and the transition from classical Poisson brackets to quantum commutators.
  • Another participant elaborates on the evolution of observables in quantum mechanics, linking classical equations of motion to their quantum counterparts.
Participants express differing views on the motivations and implications of representing observables as operators. While some agree on the mathematical basis, others emphasize the historical context and the lack of proof for this postulate. The discussion remains unresolved regarding the foundational reasoning behind these representations.
Participants note that the motivations for these representations may depend on mathematical definitions and historical developments, which are not universally agreed upon. The discussion highlights the complexity of transitioning from classical to quantum mechanics without reaching a consensus on the foundational aspects.
Lostinthought
i have been trying to learn a bit of quantum mechanics,this is some thing that has been bothering me ,
if the states of a system can be expressed as vectors in the Hilbert space,what is the motivation behind saying that physical observables can be given by operators?even then ,how can we say that the values they take are given by their eigenvalues?can this be proved somehow or reasoned out?
This is a postulate of QM, and as a postulate, it is not proven.
if its a postulate then what motivates it?
the motivation is purely mathematical. in Hilbert space, you can think of physical observables as matrix transformations. it so happens that a matrix transformation has a set of eigenvalues and eigenfunctions defined for it mathematically. these then corresponde to the possible values of the observable and the set of eigenstates of the system
Hi Ardie,
Can you give a a physical example of matrix transofrmation or how it may represent a physical process other than observables? Thanks
for example the hamiltonian in 1 dimension is a 2by1 matrix, that acts on a 1by1 vector (scalar psi) to give the scalar value of observable energy of the system (E)
the act of transformation by a matrix is simply multiplying the vector by a matrix. you do this when u operate on psi with d/dx or d/dt or multiply etc, all these operations can be encoded into a matrix relation, and hence the analogy to Hilbert space.
I think the motivation came from the historic development of QM as the matrix mechanics of Heisenberg, Born and Jordan. Namely, the canonical Poisson bracket of two "observables" [itex]f(q, p)[/itex] and [itex]g(q, p)[/itex]:
[tex] \left\{f, g\right\} \equiv \sum_{k = 1}^{s}{\left(\frac{\partial f}{\partial q_{k}} \, \frac{\partial g}{\partial p_{k}} - \frac{\partial f}{\partial p_{k}} \, \frac{\partial g}{\partial q_{k}}\right)}[/tex]
"goes over to" a commutator:
[tex] -\frac{i}{\hbar} \, \left[F, G\right][/tex]
The simplest objects that do not commute are matrices. That is why the observables are correspondent to matrices and the new mechanics was called matrix mechanics.
The equation of evolution for a classical observable [itex]f(q, p)[/itex] is given by a Poisson bracket:
[tex] \frac{d f}{d t} = \left\{f, H\right\}[/tex]
where [itex]H = H(q, p)[/itex] is the Hamiltonian of the system, should go over to the Heisenberg equation of motion:
[tex] \frac{d F}{d t} = -\frac{i}{\hbar} \, \left[F, H\right][/tex]
Every matrix can be written as:
[tex] F(t) = U^{-1}(t) \, f \, U(t)[/tex]
where [itex]f[/itex] is a diagonal matrix with the eigenvalues as the diagonal elements and the time evolution is given by the evolution matrix [itex]U(t)[/itex]. The above equation of motion is then equivalent to:
[tex] \frac{d U(t)}{d t} = -\frac{i}{\hbar} \, H \, U(t), \ \frac{d U^{-1}(t)}{d t} = \frac{i}{\hbar} \, U^{-1}(t) \, H[/tex]
Thank you ardie.
  • · Replies 16 ·
  • · Replies 61 ·
  • · Replies 59 ·
  • · Replies 27 ·
