New Reply
Imagine a solid, non-conducting cylinder at rest in IRF K, with a
Share Thread
Jun27-11, 10:31 AM   #1
Imagine a solid, non-conducting cylinder at rest in IRF K, with a positive spherical charge centered on one end and a negative spherical charge on the other end. Each charge experiences an electric force toward the other. The cylinder is compressed, but there is no torque.
Let us say that the cylinder’s axis makes an angle, A, with the x-axis, such that 0<A<90 degrees. Viewed from frame K’, each charge experiences a net electromagnetic (Lorentz) force that does not point along the cylinder’s axis. Together the charges exert a nonzero torque about the cylinder’s midpoint. Yet in K’ (as in K) the cylinder does not rotate. What counteracts the Lorentz torque in K’?
Bonus question: why don’t the charges slide/roll off the cylinder ends in K’?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jun27-11, 10:56 AM   #2
Astro/Cosmo 2012
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
It doesn't seem like you defined K'. A diagram would really help here.
Jun27-11, 10:58 AM   #3
Recognitions:
Assuming that K' is moving relative to K along the x-axis, then K' will see a magnetic field that cancels the torque. I haven't got time to do the calculation, but that's the usual answer.
Jun27-11, 07:46 PM   #4
Quote by bcrowell View Post
K and K' are both rectangular coordinate systems, with their x/x', y/y' and z/z' axes overlaid at t=t'=0. Let K move in the negative x direction at constant speed v. In this case the cylinder and charges move in the positive x' direction of K' at constant speed v. I don't know how to do a diagram in one of these replies, but hope you get the idea.
Jun27-11, 09:16 PM   #5
Quote by Mentz114 View Post
The idea is that, relative to K', the electric force still points along the chord between the 2 charges, but the magnetic force is parallel to the y' axis. Thus the sum of the 2 forces (i.e., the Lorentz force) does not generally point along the chord between the 2 charges. Together, the 2 Lorentz forces create a force couple (and torque) around the chord midpoint.
Jun28-11, 11:27 AM   #6
Recognitions:
Quote by GRDixon View Post
Could you show your calculation ?
Jun28-11, 02:21 PM   #7
I must confess that I haven't considered any particular case. I simply used the right hand rule to convince myself that the electric force and the magnetic force on a given charge don't point in the same direction, when things are viewed from K'. The net Lorentz forces on the two charges produce a torque on the cylinder. Yet the cylinder doesn't rotate. (All parts of it move with the same, common velocity in K'.) Since the cylinder doesn't rotate, there must be a counter torque. The only thing I can think of is that the compressed cylinder itself must exert a reaction torque on the charges. This is consistent with the Lorentz transformation result that the cylinder's ends are not at right angles to its walls, when things are viewed from K'. (That is why the charges don't roll off the ends in K'.) Thanks for your interest. I've never seen this problem discussed in an electromagnetism text.
Jun28-11, 03:01 PM   #8
Recognitions:
I haven't read this closely, and I can't quite envision the situation, but the general description sounds a lot like the classic "lever paradox", first proposed by Lewis and Tollman,and related to the Trouton-Noble experiment with the rotation of a charged capacitor.
There's a paper at http://arxiv.org/abs/0805.1196 with a bibliography, I'm not terribly sure of this paper's approach yet (the paper does appear to be peer-reviewed). However, it's different from the papers I've read in the past. So as usual, let the reader beware.
Jun30-11, 04:11 PM   #9
Thanks, Pervect. I have checked out the link and will spend more time thinking about the whole thing. I was aware of the Trouton-Noble experiment.
Jun30-11, 05:13 PM   #10
Recognitions:
The standard derivation that internal forces don't contribute to angular momentum requires that the force between any pair of particles lies along a line connecting them, if you go back and read the fine print in your standard physics textbook (i.e. Goldstein, for example).
This assumption becomes a bit problematical in the context of SR. I've seen various discussions of the issue but I'm not really super-happy with any of them.
Jun30-11, 07:21 PM   #11
Astro/Cosmo 2012
Recognitions:
Quote by pervect View Post
And that assumption can fail for electromagnetic forces. The interpretation is that the angular momentum is carried away by electromagnetic waves.
As an example, if you start a dipole spinning, its spin will slow down as it dissipates its energy and angular momentum into the energy and angular momentum of the electromagnetic waves it radiates. I don't know if this is quite what the OP had in mind.
Jul4-11, 03:12 PM   #12
You might try Googling "Trouton Noble Revisited".
Jul4-11, 05:47 PM   #13
Recognitions:
Thanks. I will.
New Reply
Similar discussions for: Imagine a solid, non-conducting cylinder at rest in IRF K, with a
Thread Forum Replies
The sum of torques is not the sum of torques? Introductory Physics Homework 8
summation of torques Introductory Physics Homework 1
Torques Introductory Physics Homework 1
CW/CCW Torques Introductory Physics Homework 5
HELP PLEASE Torques Introductory Physics Homework 3
