A lightly damped harmonic oscillator
The discussion focuses on deriving the relationship between the logarithmic decrement (δ) and the quality factor (Q) of a lightly damped harmonic oscillator. The logarithmic decrement is defined as δ = ln(An/An+1), where An represents the maximum displacement of the n-th cycle. Given the parameters: mass (m = 4.0 kg), frequency (f = 0.9 Hz), and logarithmic decrement (δ = 0.029), participants are tasked with calculating the spring constant (k) and damping constant (b) using the equations β = b/(2m), ωo = (k/m)^(1/2), and Q = ωo/(2β). The discussion emphasizes that solving the differential equation is essential to find a general solution.
  • Understanding of harmonic oscillators and their dynamics
  • Familiarity with logarithmic decrement and quality factor in oscillatory systems
  • Knowledge of differential equations related to mechanical systems
  • Basic principles of oscillation frequency and spring constants
  • Calculate the spring constant (k) using the formula k = m(ωo)^2
  • Determine the damping constant (b) from the relationship b = 2mβ
  • Explore the implications of underdamped oscillators in practical applications
  • Learn more about the significance of the quality factor (Q) in oscillatory systems
Students and professionals in physics, particularly those studying mechanical vibrations, engineers working with oscillatory systems, and anyone interested in the dynamics of damped harmonic oscillators.
kraigandrews
The logarithmic decrement δ of a lightly damped oscillator is defined to be the natural logarithm of the ratio of successive maximum displacements (in the same direction) of a free damped oscillator. That is, δ = ln(An/An+1) where An is the maximum displacement of the n-th cycle. Derive the simple relationship between δ and Q.
Find the spring constant k and damping constant b of a damped oscillator with mass m, frequency of oscillation f and logarithmic decrement δ.
[Data: m = 4.0 kg; f = 0.9 Hz; δ = 0.029.]
First, the spring constant k...
Also, the damping constant b...
[itex]\beta[/itex]=b/(2m)
[itex]\omega[/itex]o=(k/m)1/2
Q=[itex]\omega[/itex]o/(2[itex]\beta[/itex])
Ok so I do not know where to start, I can solve the equation:
d2x/dt2+2[itex]\beta[/itex]dx/dt+[itex]\omega[/itex]o2x=0
but other than that I have no idea where to go. My best guess is that it is unnecessary to solve it because no initial conditions are given thus one would be unable to find the constant or any initial amplitude. any help is greatly appreciated.
thanks
You do need to solve the equation. Find a general solution given the parameters in the equation, and go from there. From reading the problem, I think you can assume the oscillator is underdamped.
