G.M. Hossain new paper on inflation
  • Context: Graduate
  • Thread starter Thread starter marcus
    Inflation Paper
The discussion centers around G. M. Hossain's new paper on loop quantum cosmology (LQC) and its implications for inflationary models in cosmology. Participants explore the potential for testing LQC against standard inflation scenarios through the cosmic microwave background (CMB) power spectrum, as well as the comparative analysis of LQC-induced inflation versus traditional inflation models.
  • Some participants highlight that Hossain's paper suggests a method for testing LQC cosmology against standard inflationary scenarios by examining the CMB power spectrum.
  • Hossain's comparison indicates that standard inflation requires multiple levels of fine-tuning of field parameters, while LQC-induced inflation does not necessitate such fine-tuning for several key requirements.
  • It is noted that the initial, sustaining, and ending phases of inflation in LQC can occur naturally without fine-tuning, which contrasts with the standard model's requirements.
  • Some participants mention that the small amplitude of primordial density perturbations is a natural prediction of effective loop quantum cosmology.
  • There is a discussion about the ambiguity parameter j in LQC, which influences the amount of expansion generated during inflation.
  • Some participants express interest in the spectral index predicted by LQC, noting its potential for falsifiability and comparison with the standard model's predictions.
  • Geographical and biographical details about G. M. Hossain are shared, including his affiliations and background, although these are not directly related to the technical discussion.
Participants express a range of views regarding the implications of Hossain's findings, with some supporting the advantages of LQC over standard inflationary models, while others focus on the geographical and personal context of Hossain's work. The discussion remains unresolved regarding the comparative efficacy of the two inflationary scenarios.
There are references to specific equations and results in Hossain's paper that are not fully detailed in the discussion, which may limit understanding of the claims made about spectral indices and inflationary dynamics.
marcus
Dearly Missed
G. M. Hossain posted a new Loop cosmology paper today.
http://arxiv.org/gr-qc/0411012
Primordial Density Perturbation in Effective Loop Quantum Cosmology
It suggests a way of testing LQG cosmology against standard scenarios by looking at details of the CMB power spectrum. A step in the direction of falsifiability (the criterion of when a theory is scientifically meaningful)
Along with discussing this possible test of the theory, Hossain made a comparison of LQG-induced inflation versus put-in-by-hand or long-shot inflation scenarios. See also
M. Bojowald, “Inflation from quantum geometry,” Phys. Rev. Lett. 89, 261301 (2002) http://arxiv.org/gr-qc/0206054 .
G. Date and G. M. Hossain, “Genericity of inflation in isotropic loop quantum cosmology,” http://arxiv.org/gr-qc/0407069 .
---quote from page 25 of gr-qc/0411012 ---
Before we discuss the implications of possible outcomes of mentioned test let us have a comparative study of standard inflationary scenario and loop quantum cosmology induced inflationary scenario.
In order to have a successful inflation in the standard scenario, generally one requires multi-level of fine tuning of field parameters. In other words one faces several kind of naturalness problems to achieve a successful inflation.
The first one is to start inflation. In standard inflationary scenario it is needed to choose initial field velocity to be sufficiently small so that the equation of state [is approximately -1].
The second one is to sustain inflation. In standard scenario one requires to choose the field potential to be flat enough so that field does not gain momentum quickly.
The third one is to generate sufficient expansion (to solve horizon problem and others). To achieve this in standard scenario, one requires to choose the initial field configuration sufficiently uphill in the potential. In other words, one requires to fine tune initial field configuration.
The fourth one is to end inflation. In many cases this requires sort of potential engineering to have a long flat plateau and then a fast fall-off in the potential profile.
The fifth one is to produce small amplitude for primordial density perturbation. To produce observed small amplitude of density perturbation one needs to fine tune parameters of the field potential. This fine tuning is basically required to compensate the ‘third’ fine tuning.
On the other hand, to achieve the first, second and fourth requirements in loop quantum cosmology induced inflationary scenario one does not require to fine tune the parameters. These requirements are naturally achieved as they simply follow from the spectrum of the inverse scale factor operator.
The fifth requirement i.e. small amplitude, as shown in this
paper, is a natural prediction of effective loop quantum cosmology.
The situation regarding the third problem also gets improved significantly. In the loop quantum cosmology, the generated amount of expansion is controlled by the ambiguity parameter j. Clearly to produce sufficiently large expansion, using loop quantum cosmology alone, one will require to choose the value of j to be large. Thus it is very likely that only the initial part of the inflation was driven by loop quantum cosmology modification. It has been argued in [40, 41, 42] that the loop quantum cosmology induced inflationary phase can lead to a secondary standard inflationary phase. This follows from the fact that the in-built inflationary period of loop quantum cosmology can produce favourable initial conditions for an additional standard inflationary phase. Since the observed part of CMB angular power spectrum generally corresponds to early period of inflation then it may well be the situation where the observed part of the CMB angular power spectrum corresponds to the loop quantum cosmology driven inflationary period. It is worthwhile to emphasize that high amount of expansion in this scenario is required not to solve horizon problem (being non-singular this model avoids horizon problem [22]) rather to avoid a different kind of problem...
---end quote---
a little geography
G.M.Hossain seems to be dividing his time these days between
Albert Einstein Institute-Gölm (where Bojowald and Thiemann are)
and the Institute for Mathematical Sciences (imsc) at CHENNAI
so I want to know where Chennai is.
turns out that it is the new name of the city of Madras
http://www.imsc.res.in/Madras/mad-map.html
So it is in the Tamil-speaking south, and it is on the East coast.
And the Institute is near the bottom border of the map here, where you
see the letters C.I.T. (a large complex of scientific institutions sort of like the "Research Triangle" in North Carolina I guess) Some websites call the C.I.T India's "science city"---the acronym's for "central institutes of technology".
Bojowald has co-authored several papers with Hossain and IIRC some
of their work has been done while Bojowald was a visitor at Chennai.
So the traffic between Berlin and Chennai is two-way.
some background on G.M.Hossain
Hossain was born in 1980, so he is 24 years old
Here's a snapshot
http://www.imsc.res.in/~golam/second_page.html
Here are Hossain's papers:
http://arxiv.org/find/gr-qc/1/au:+Hossain_G/0/1/0/all/0/1
[edit: in the next post nonunitary tells me that the person with Bojowald
in this picture is Alejandro Perez, i had mistakenly thought it might be
Hossain.
http://perimeterinstitute.ca/images/marseille/marseille017.JPG ]
Hi,
The guy looking at the camara in the marseille picture is Alejandro Perez.
nonunitary said:
Hi,
thanks for the correction, nonunitary. I fixed the error in the preceding post.
I've anoted in my notebook the spectral index of eq. 43. It's interesting that LQC is able to predict a spectral index, so it can be falsifiable and compared with the spectral index proposed by the Standard Model of Cosmology
  • · Replies 28 ·
  • · Replies 62 ·
13K
