Wireless music transmission using lasers
This discussion centers on using lasers for wireless music transmission from an iPod. The setup involves a laser connected to the iPod, aimed at a solar cell, which is then linked to a stereo cable. Users report low sound output from the speakers and seek advice on building an op-amp amplifier to enhance the signal. Suggestions include using a single signal amplifier for each audio channel and considering a photodiode instead of a solar cell for better frequency response.
  • Understanding of op-amp amplifier design
  • Knowledge of laser modulation techniques
  • Familiarity with audio signal transmission
  • Basic electronics involving solar cells and photodiodes
  • Research op-amp amplifier circuits for audio applications
  • Learn about laser modulation methods for audio signals
  • Explore the differences between solar cells and photodiodes in audio transmission
  • Investigate circuit designs for dual-channel audio amplification
Electronics enthusiasts, audio engineers, and hobbyists interested in innovative audio transmission methods using lasers.
roz77
Hey all. I'm currently working on a project where I use a laser to transmit music playing from my iPod. The laser is hooked up to the iPod through a circuit, and there is a solar cell that the laser is pointed at. There are two wires coming from the solar cell that are connected to a stereo cable. My problem is that the sound coming from the speakers is very quiet, and I want to build an op-amp amplifier for the signal. I've searched for some stuff online but I keep getting a bunch of different things. Can I just basically use a single signal amplifier for each channel separately? Or do I have to build a more complex circuit to handle both of the channels? Thanks for your help.
Could you please show more details for the transmitting and receiving circuits that you are currently using? That will help a lot in determining what else you should add at the receiver.
What power TX laser are you using, and how are you modulating its amplitude?
roz77 said:
The laser is hooked up to the iPod through a circuit, and there is a solar cell that the laser is pointed at. There are two wires coming from the solar cell that are connected to a stereo cable. My problem is that the sound coming from the speakers is very quiet,...
Is your stereo cable connected directly to the speakers or does it go through an amplifier? If not you should try amplifying it before feeding it to the speakers.
I don't know the frequency response of solar cells. I've never seen it specified so I assumed it wasn't very good. If you lack high frequencies you may consider using a photo diode instead of solar cells. A photo diode doesn't produce current like solar cells, but merely varies its resistance in response to varying light levels. A photo diode may also be more sensitive than solar cells but you still will need an amplifier.
  • · Replies 37 ·
  • · Replies 24 ·
  • · Replies 28 ·
  • · Replies 26 ·
