Redox reaction for sour solution
  • Thread starter Thread starter Mathman23
    Oxidation
The discussion centers on the redox reaction involving iron(III) ions and sulfite ions in a sour solution created by adding sodium bisulfite (NaHSO3). The reaction is represented as Fe3+ + HSO3- → Fe2+ + SO42-, where iron(III) is reduced to iron(II) while sulfite is oxidized to sulfate. The addition of NaHSO3 alters the color of the solution to yellow and affects the equilibrium of the reaction, suggesting a shift towards the formation of Fe(SCN)+. The discussion also highlights the need for balancing the reaction with water and hydroxide ions.
  • Understanding of redox reactions and electron transfer
  • Familiarity with chemical equilibrium concepts
  • Knowledge of iron chemistry, specifically iron(III) and iron(II) ions
  • Basic grasp of sulfite and sulfate chemistry
  • Study the detailed mechanisms of redox reactions involving transition metals
  • Learn about chemical equilibrium and Le Chatelier's principle in redox systems
  • Investigate the properties and reactions of sodium bisulfite in acidic solutions
  • Explore the colorimetric changes in transition metal complexes during redox reactions
Chemistry students, researchers in inorganic chemistry, and professionals working with redox reactions in laboratory settings will benefit from this discussion.
Mathman23
Hi All,
[itex]\mathrm{Fe^{3+}(aq) + SCN^{-} (aq) \rightleftharpoons FeSCN^{2+}(aq)}[/itex]
I add some [itex]\mathrm{NaHSO_{3}(s)}[/itex] to the above reaction !
This makes the above chemical solution sour, consequently in a sour solution [itex]\mathrm{HSO^{-}_{3}}[/itex] will reduce Fe^{3+} to Fe^{2+}, meanwhile [itex]HSO_{3}^{-}[/itex] is itself oxidated to [itex]SO^{2-}_{4}[/itex].
a/ The color of the original resolution changes then adding [itex]\mathrm{NaHSO_{3}(s)}[/itex] to yellow.
b/ By adding [itex]\mathrm{NaHSO_{3}(s)}[/itex] to the orginal solution the equilibrium direction changes, such that it runs from right to left.
c/ I need help writing the reaction between [itex]HSO^{-}_{3}[/itex] and [itex]SO^{-}_{4}[/itex].
d/ Which influence does the adding of [itex]HSO^{-}_{3}[/itex] have on the concentration of [itex]Fe^{3+}[/itex]
I hope that there someone out there who is willing to assist me since this is my last post !
Sincerely
Fred
Chemistry news on Phys.org
Hello,
Let me first do the redox thing in atomic level, since it's easier than dealing with a bunch of atoms.
We know that iron(III) is reduced to iron(II), and in turn, sulfite (S4+) is oxidized to sulfate (S6+):
[tex]S^{4+} \longrightarrow S^{6+}+2e^-[/tex]
[tex]2Fe^{3+}+2e^-\longrightarrow 2Fe^{2+}[/tex]
[tex]S^{4+}+2Fe^{3+} \longrightarrow S^{6+}+2Fe^{2+}[/tex]
In the real redox, you'll need to put some other correcting factors (water and hydroxide, I think) to balance additional oxygens.
Now that we've got rid of the redox reaction, we may look other things. When you add some sodium bisulfate to the medium, a redox reaction occurs; and so the thiocyanate complex changes from [itex]\displaystyle Fe(SCN)^{2+}[/itex] to [itex]\displaystyle Fe(SCN)^+[/itex]; this gives a totally different color. Iron(II) sulfate is also formed from the reaction, and the color may have also come from this one, so I don't think that the equilibrium shifts to the left, but I may be wrong; I don't insist on that.
