Relativity and Probability Waves
This discussion centers on the interplay between Einstein’s Theory of Relativity and Feynman’s Sum Over Histories (SOH). It establishes that observers in differentially moving frames of reference perceive measurements such as speed, time, and mass differently, yet all perspectives are valid. The conversation highlights that gravitational fields are also perceived differently based on the observer's frame of reference, suggesting a unique gravitational topology for each observer. Additionally, it clarifies that Feynman's SOH serves as a mathematical tool to calculate probabilities rather than deterministic outcomes, emphasizing the distinction between classical and quantum interpretations of relativity.
  • Understanding of Einstein’s Theory of Relativity
  • Familiarity with Feynman’s Sum Over Histories (SOH)
  • Basic knowledge of quantum mechanics and wave-particle duality
  • Concept of frames of reference in physics
  • Research the implications of Einstein’s Theory of Relativity on measurements in physics
  • Study Feynman’s Sum Over Histories and its applications in quantum mechanics
  • Explore the concept of gravitational topology and its relevance in different frames of reference
  • Investigate the relationship between classical and quantum interpretations of reality
Physicists, students of quantum mechanics, and anyone interested in the foundational principles of relativity and their implications on measurements and observations in the universe.
PaulMurphy
I don't know enough physics to know where my reasoning or assumptions are incorrect in this post. Please point me in the right direction so I can fill the holes in my knowledge that led to this conjecture:
In Einstein’s Theory of Relativity, there is no absolute motion, no absolute rest and every differentially moving frame of reference is equally valid. Observers in differentially moving frames of reference will measure an object’s speed, radioactive decay rate (time) and mass to have different values. These measurements from differentially moving frames of reference are all equally valid.
In the case of gravity, I suggest that an observer in one frame of reference will map the gravitational fields present in the Universe differently than an observer in a differentially moving frame of reference. In essence, each relatively moving frame of reference has a separate gravitational topology of the Universe. They would each create a different map of gravitational fields from their own equally valid perspectives.
I suggest that every particle that could potentially be observed has a range of properties that would be observed to have different values when measured from differentially moving frames of reference.
If particles could theoretically be measured to have different values for properties when viewed from relatively moving frames of reference, then maybe the values of these properties are described by a separate history in a way similar to Feynman’s Sum Over Histories and the probability wave for each property has the locally highest probability for the most likely value in each local frame of reference.
Thanks!
Paul Murphy
No, the two do not "differ" in the same way.
Relativity simply means that the same object looks different from different perspectives. For example what you see as a vertical line I might see as a diagonal line because our orientations are different. We will measure different components (x extent and y extent) but we can map one perspective to the other via a relativity transformation (coordinate rotation in this case).
Einstein's relativity is a bit harder to grasp because we normally think of time as a universal absolute and not as one component in the space-time separation of two events.
In the above cases (when applied to classical systems) there is a single objective history for an object, it is just broken down into components differently due to different observers.
In the Feynman's SOH one is rather summing over all the available classical histories to determine the transition amplitude (and thence transition probability) between two observations. What's happening while this summing is going on is necessarily not observed. In one sense this summing might be considered just a calculation method i.e. purely a mathematical procedure. Remember it doesn't predict deterministically a single system's behavior, it rather predicts probabilities which are confirmed over many trials of the same experiment.
Most importantly, as far as seeing the misalignment of the two cases you're trying to identify, there is no relativity transformation from one path to another path within these many histories. Each may be distinctly different from the other. If you want to better understand Feynman's SOH look up http://en.wikipedia.org/wiki/Huygens-Fresnel_principle" which states (roughly) that a wave propagates as if everywhere along its wave-front a point source is emitting a spherical wave with the same amplitude. Thus to see how the wave looks at a given point you can sum over the contributions from each point on a surface it crosses. Applying this recursively you have a classical "sum over histories" of a wave.
Feynman's SOH is a manifestation of the wave part of the wave-particle duality for quantum particles. Now there is in this duality a deeper "relativity principle" in the relative representation of the system, sort of a "relativity of reality" which lies deep in the heart of QM. But this "relativity" lies at a distinctly different level of abstraction from the conventional space-time relativity and they are not the same.
  • · Replies 20 ·
  • · Replies 33 ·
  • · Replies 51 ·
  • · Replies 57 ·
  • · Replies 16 ·
