How to learn assembly code for debugging VC++?
The discussion revolves around learning assembly code to enhance debugging skills in Visual C++. Participants share resources, experiences, and suggestions for understanding low-level programming, particularly in the context of debugging and working with assembly code.
  • Homework-related
  • One participant expresses a desire to learn assembly to better understand low-level operations and improve programming skills, noting their background in high-level programming.
  • Another participant suggests obtaining architecture manuals from CPU vendors like Intel and AMD, emphasizing the importance of understanding instruction sets and flow-control.
  • A different participant warns that the assembly code seen during debugging may not always be relevant to the program, suggesting that it could be garbage due to earlier errors.
  • Some participants recommend learning assembly alongside practical examples and debugging exercises, with one suggesting starting with an easy-to-understand book.
  • Links to online resources, such as the Flat Assembler manual, are provided, with notes on the specific sections relevant to x86 assembly.
  • Discussion includes the importance of knowing the specific assembler being used, as different assemblers have different syntax and features.
  • One participant shares their positive experience with Fasm due to its simplicity and GUI, while another discusses using Microsoft Assembler (MASM) and the transition to ml.exe for assembly tasks in Visual Studio.
Participants generally agree on the importance of learning assembly for debugging, but there are multiple views on the best resources and methods for doing so. The discussion remains unresolved regarding the most effective approach to learning assembly code.
Participants mention the potential limitations of older books and resources, as well as the need for familiarity with specific assemblers and their syntax. There are also references to issues with Visual Studio versions and library function availability.
chingkui
Sometimes when I try to debug my codes, VC++ brings me something I believe are assembly codes which I couldn't read at all. I want to know where I can learn these to better understand what is going on at low level. I am quite comfortable with high level programming, but I believe I really need to understand more about low level stuffs to improve my programming skills. Anyone has books/websites suggestion I can learn this skill? (a little background: I am a computational scientist/applied mathematician, learn high level programming myself, never taken any C.S. class in programming/architecture. So, I am almost completely clueless in low level operations)
Thanks.
Technology news on Phys.org
Hey there chingkui.
I have a few suggestions for you.
The first suggestion is to get architecture manuals from CPU vendor websites like Intel and AMD. The documents from these sites will contain information on architecture/ instruction sets/ and standards that will help you understand the flow-control, optimizations, interaction with hardware and so on. The key document for you is the instruction set document. There should be documents for both 32 and 64 bit program environments.
If you are not dealing with things like device drivers, you will probably ignore a subset of the instruction set like hardware operations (IN, OUT) as well as some instructions like IRET. You said you're working with VC++ which implies Windows which implies no direct hardware access (hardware interrupts, ports, etc).
Using the above in conjunction with code samples and examples in conjunction with your own code that you write to gain experience is a good way to start, fiddle with, and eventually master assembly.
The reason I'm not recommending books per se, is because many books that I have read are very old. Its true that most of the commands and their use at the machine language level have mostly stayed the same, but there has been a big difference in memory addressing between segmented addressing and flat memory addressing. This is a primary reason why I am not advocating old assembler books.
If you have any questions, I'll try my best to answer them.
That most likely means some earlier error resulted in instruction pointer being moved outside machine code generated by compilation of your program. While understanding assembly won't hurt, at this stage code you see is often either garbage, or completely unrelated to your program.
Learning assembler is little easy when you learn it in conjunction with examples and by debugging those example programs using a separate program. Start by referring an easy to understand book. Good Luck!
That's part of the learning process. Its rare that you become a good programmer without having to debug a program, no matter what language, platform, environment its in.
TylerH said:
Here's a good reference for use in conjunction with the Intel/AMD manuals: http://flatassembler.net/docs.php?article=manual#2.1
Note: Only section 2.1 is related to x86 assembly, the rest is related to the Fasm assembler itself.
You brought up a great point that I want to emphasize to the OP: You will need to know specific issues about the assembler you are using. Different assemblers usually have different syntax for whatever reason so knowing this and how to use it is also important.
Personally I've only used the Microsoft Assembler (MASM), but there are others out there including NASM, TASM (Turbo Assembler), and probably others. I found MASM pretty good, but I don't have experience with others (the only exception is __asm code within VC).
Hopefully someone can chime in on their experiences with other Assemblers.
Fasm is great. It has a focus on simplicity. But to be honest, I learned assembly with it for the singular reason that it has a GUI. I really didn't want to learn to use Nasm or Tasm with command line at the time. I discovered all of its other features well after the fact of deciding on which to use.
In the case of Microsoft tools, masm.exe has been replaced by ml.exe (masm + linker). ml.exe is still included with Microsoft's Visual Studio, but you have to manually edit a project to include the command line step to assemble source code using ml.exe. I've done a few projects that are assembly code only, using Visual Studio. You create an empty console project, then add the .asm source code to the project. Then for that .asm source file, you need to create a custom build step to invoke ml.exe:
ml /c /Fo$(outdir)\example.obj example.asm
or use this to include debugging info (just add the \Zi):
ml /Zi /c /Fo$(outdir)\ge32.obj ge32.asm
Once this is done, you can use use the Visual Studio standard GUI interface to build and debug the program. To trace through assembly code with the debugger, you'll want to enable the debugger's register view.
To determine the INCLUDELIB and EXTRN (library function calls) statements needed to use standard c library calls for a console project, I create a small C console project and output assembly code, then copy that to the test assembly source file.
One issue is that some of the free "express" versions of visual studio don't include the standard c library functions for console projects. There may be a work around but I haven't tired to figure this out since I use VS 2005, which I bought a long time ago.
  • · Replies 102 ·
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 25 ·
  • · Replies 17 ·
