Cannon physics: detailed inquiry of projectile propellant.
In summary, the conversation revolved around ways to alleviate boredom by exercising the brain through physics. The focus then shifted to the process of propelling a projectile from a cannon and the physics involved. The speaker questioned whether this process is adiabatic and considered the ideal gas law, but realized it may not apply in this case due to the density of the explosives. They also brought up the concept of shock waves and sought help understanding the physics involved in a cannon. Two recommended references for further reading were also mentioned.
frankR
91
I was bored earlier today, so I concluded the best way to elevate my boredom was to exercise my brain for next quarter. The best way to exercise your brain is to do a little physics, right?
I started to think of a problem. I came up with a classic projectile problem: A cannon fires a projectile at some angle and impacts at some x-y coordinate, find the initial speed of the projectile, BORING!
Why not look at the more complete picture of cannon physics, specifically the propellant that accelerates the projectile.
I started by drawing a diagram of the barrel of the cannon, diameter/length. I know cannons have a charge (explosive) behind the projectile (chamber) which combusts to produce a high pressure gas in the chamber. The pressure exerts a force on the rear surface area of the projectile, which causes the projectile to acceleration until the rear of the projectile exits the end of the barrel.
Is this process adiabatic? Is it correct to say: the expansion of the gas happens so rapidly no energy can be transferred from the gas to the barrel or projectile as heat? However I know gun barrels get hot and so do the projectiles, thus Q does not equal zero? Can anyone steer me in the right direction here?
I then started to think about gas pressure. Pressure is related to temperature by the ideal gas law. However the ideal gas law operates under the assumption that the gas density is low enough to assume the gas particles don’t occupy a volume or interact with each other. I am fairly certain that this assumption cannot be made in this case due to the explosives being solid and thus dense before combustion occurs, so I conclude that the gas must be very dense after combustion. Writing this I’m now thinking my analysis to be inherently flawed.
Do I need to look at the energy of a shock wave? That is, the primary energy is transferred to the projectile through a shock wave? However the projectile has inertia which cannot by accelerated by a traveling wave?
If anyone knows what I’m talking about could you please help me understand (conceptually) the physics in a cannon? Even if the detail I’m eluding to can only be modeled by a computer simulation.
"Interior ballistics:" the classic references are "The Bullet's Flight from Powder to Target," Mann and Pope; and, "Complete Guide to Handloading," Sharpe. These should be in university libraries, or you can pick them up at gun shows --- scarce, but not book collectors' treasures.
Related to Cannon physics: detailed inquiry of projectile propellant.
1. What is a cannon?
A cannon is a large gun that uses gunpowder or other explosive propellants to launch a projectile at a high speed and over a long distance.
2. How does a cannon work?
A cannon works by igniting gunpowder or another propellant in a closed chamber, which creates a large amount of gas and pressure that propels the projectile out of the cannon's barrel.
3. What factors affect the trajectory of a cannon's projectile?
The trajectory of a cannon's projectile is affected by factors such as the angle of the cannon's barrel, the amount and type of propellant used, the weight and shape of the projectile, and external forces such as wind and gravity.
4. How does the type of propellant used affect the performance of a cannon?
The type of propellant used can greatly affect the performance of a cannon. For example, gunpowder produces a large amount of gas quickly, resulting in a powerful launch, while other propellants may produce a slower but more sustained force. The use of different propellants can also affect the accuracy and range of a cannon.
5. How has the design and technology of cannons evolved over time?
The design and technology of cannons have greatly evolved over time. Early cannons were made of wood and fired stone or iron balls, but later advancements such as the development of cast iron cannons and rifling (grooves inside the barrel) greatly improved their accuracy and range. Modern cannons also use more advanced propellants and materials, making them even more powerful and precise.
  • Materials and Chemical Engineering
  • General Engineering
  • Classical Physics
  • Mechanics
