What is the volume of the secret cavity in this submerged sculpture?
  • Thread starter Thread starter skonstanty
    Volume Water
The volume of the secret cavity in a submerged brass sculpture, weighing 15.76N in air and 13.86N in water, is calculated using Archimedes' principle. The buoyant force, equal to the weight difference, allows for the determination of the cavity's volume. By applying the formula Volume = (Weight in air - Weight in water) / Density of brass, the volume is found to be 0.000224 cubic meters. This calculation is essential for understanding the properties of submerged objects.
  • Understanding of Archimedes' principle
  • Knowledge of buoyant force calculations
  • Familiarity with density and volume relationships
  • Basic physics concepts related to submerged objects
  • Study the applications of Archimedes' principle in fluid mechanics
  • Explore advanced buoyancy calculations for irregularly shaped objects
  • Learn about the properties of different materials and their densities
  • Investigate the effects of temperature and pressure on buoyancy
Physics students, engineers, and anyone interested in fluid dynamics and the principles of buoyancy will benefit from this discussion.
skonstanty
A small sculpture made of brass (density = 8470 kg/m cubed) is believed to have a secret central cavity. The weight of the sculpture in air is 15.76N. When it is submerged in water, the weight is 13.86 N. What is the volume of the secret cavity?
what have you done?
you must be familiar with archimedes principle, i suppose.
Well you know the buoyant force is equal to the mass of the fluid displaced times gravity. When the object is submerged, its weight is less due to the buoyant force.
Use the relationship [itex]\rho = \frac{m}{v}[/itex] in the problem, and remember the volume of the fluid displaced is equal to the volume of what is submerged (in this case the entire object).
To calculate the volume of the secret cavity, we can use the formula:
Substituting the given values, we get:
Volume = (15.76N - 13.86N) / 8470 kg/m^3
= 1.9N / 8470 kg/m^3
= 0.000224 m^3
Therefore, the volume of the secret cavity in this submerged sculpture is 0.000224 cubic meters.
  • · Replies 25 ·
  • · Replies 22 ·
