How Does Inorganic Chemistry Explain Chemical Phenomena?
  • Thread starter Thread starter Ashu2912
    Chemistry Works
The discussion revolves around the nature of theories in inorganic chemistry and their role in explaining chemical phenomena, particularly regarding bonding and the synthesis of new compounds. Participants explore whether theories are primarily designed to explain existing observations or if they also facilitate the prediction of new compounds based on theoretical frameworks.
  • Exploratory, Conceptual clarification, Debate/contested
  • One participant questions whether theories in inorganic chemistry are solely for explaining existing chemical phenomena or if they also allow for the creation of new compounds based on theoretical possibilities.
  • Another participant asserts that the usual scientific approach is to develop theories that explain known phenomena and then test their predictive power for new observations.
  • A participant suggests that the inquiry should focus on understanding why certain phenomena occur rather than why they do not, implying a distinction in the approach to theory development.
  • Some participants express uncertainty about the clarity of the initial question, indicating that it may be repetitive or ambiguous.
  • It is proposed that not all theories are exclusively aimed at explaining phenomena, and some may indeed suggest the potential for creating new compounds from existing elements.
  • A participant emphasizes that both occurrences and non-occurrences of reactions are phenomena that should be explained by a robust theory, citing examples of sodium and gold in water to illustrate this point.
Participants express differing views on the purpose of theories in inorganic chemistry, with some arguing for a focus on existing phenomena and others suggesting a broader role that includes prediction and synthesis. The discussion remains unresolved regarding the primary intent behind the formulation of these theories.
Some assumptions about the clarity of the initial question and the definitions of phenomena may not be fully articulated, leading to potential misunderstandings among participants.
Ashu2912
How Chemistry Works?
Hey friends, I was just giving it a thought about how the science of (inorganic) chemistry works. Are all the theories formulated just in order to explain the chemical phenomena, such as bonding? Do these theories hold place for creation of new compounds based on the possible permutations satisfying the theory (that is if they are feasible thermodynamically, energetically and so on...). Or we only build theories to account for what already occurs in nature? Pls. give your opinions. Thank You!
Chemistry news on Phys.org
Usual way is to build a theory explaining known phenomena and then check if it can be used to predict something new. That's not just in inorganic chemistry, that's how the science works.
You mean to say, we should ask "Why this happens" and not "why this does not happen". Not to synthesize something new based on the theory?
Then question seems unclear. I wonder if I understand because it seems like the last question might be the same as the first.
It would probably be wrong to say all the theories are intended to explain phenomena.
I would say that some of the theories do suggest that new compounds of the same elements can be created.
It would probably be wrong to say that we ONLY build theories to account for naturally occurring phenomena.
"It doesn't happen" is a phenomena just like "it happens".
I have a piece of sodium metal that fizzles when put in water, I have a piece of gold that doesn't change when put in water. Good theory should be able to explain both cases. And such theory exists and explains both cases in terms of activity series.
  • · Replies 46 ·
  • · Replies 19 ·
11K
