Electromagnetic pickup/reluctor waveform
This discussion focuses on designing an electromagnetic pickup/reluctor that generates a specific waveform, utilizing an automotive ignition pickup. The user is experimenting with various reluctor shapes but is encountering unexpected results, particularly regarding peak voltage not increasing with RPM as anticipated. Key issues include potential impedance problems in the pickup coil and the need for a deeper understanding of the relationship between reluctor position, speed, and magnetic flux change. The user seeks assistance with relevant equations and modeling in LTSPICE to analyze high-frequency behavior.
  • Understanding of electromagnetic induction principles
  • Familiarity with automotive ignition systems
  • Knowledge of impedance and its effects on electrical circuits
  • Experience with LTSPICE for circuit simulation
  • Research the equations governing magnetic flux change in electromagnetic systems
  • Learn about the effects of impedance on signal integrity in pickup coils
  • Explore LTSPICE modeling techniques for high-frequency circuit analysis
  • Investigate different reluctor shapes and their impact on waveform generation
Engineers and designers working on automotive ignition systems, electrical engineers focused on electromagnetic applications, and hobbyists interested in waveform generation and circuit modeling.
mynode
I'm trying to design a pickup/reluctor that produces a specific waveform. I'm using an automotive ignition pickup and expermenting with different shapes of reluctor but the results I'm getting aren't making any sense.
The pickup/reluctor are of the familiar design with a pickup coil wound around a magnetic core and a ferrous reluctor moving past one end of the pickup core.
First of all, I expected peak voltage to increase as rpm increased, but it's not, at least not in the range I'm looking at. Could the problem be the the impedance of the pickup coil dissapating too much power above a certain level?
Secondly, it occurs to me that I might have better luck if I understood the underlying relationship between the reluctor position and speed and the change in magnetic flux in the pickup, but it's been too long since my college physics classes. Can anyone give me some hints or perhaps provide me with the basic equations to compute the change in flux?
It may simply be that you exceeded the bandwidth of the system, and impedances at those freuencies are just too high.
Could you make a LTSPICE model for the highest frequency and estimate the parameter values?
  • · Replies 16 ·
12K
  • · Replies 27 ·
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 37 ·
