Proof: Velocity of Light can't depend on velocity of body emitting the light
The discussion centers around the concept that the velocity of light does not depend on the velocity of the body emitting the light. Participants explore historical experiments and theoretical implications related to this idea, particularly referencing the De Sitter double star experiment and the Michelson-Morley experiment.
  • Some participants inquire about the details of the De Sitter double star experiment and its implications for the velocity of light.
  • Others suggest that if the speed of light depended on the source's motion, time-lags would be observed in eclipsing binaries, which is not the case.
  • One participant expresses confusion about how the eclipse of a fixed star relates to the concept of light's velocity independence.
  • Another participant mentions the Michelson-Morley experiment as an early demonstration that the speed of light remains constant despite the motion of the Earth.
  • Some participants note that the Michelson-Morley experiment assumes the source and receiver are at rest relative to each other, raising questions about its applicability to the emission theory.
  • One participant introduces the Sagnac effect as evidence that the speed of light is independent of the motion of the source, challenging the emission theory.
Participants express varying levels of understanding and agreement regarding the implications of different experiments on the velocity of light. Multiple competing views remain, particularly concerning the interpretation of the Michelson-Morley experiment and the validity of emission theories.
Some participants reference specific experiments and their historical significance, but there is a lack of consensus on the implications of these experiments for the emission theory of light. Unresolved assumptions about the conditions under which these experiments were conducted are noted.
haitham1984
Hello All,
I am reading a book about relativity and early on in the book I read the following:
"...By means of similar considerations based on observations of double stars, the Dutch
astronomer De Sitter was also able to show that the velocity of propagation of light
cannot depend on the velocity of motion of the body emitting the light..."
The author does not go into any detail about this experiment. My question is, could someone please either explain:
1) The experiment mentioned in the quotation above with some detail.
2) Or, explain the idea above using a different experiment (assuming one was made) which leads us to the same conclusion.
Thank you for your help.
Hi, Haitham,
Welcome to PF!
It's always helpful if you can tell us the source you're quoting from. I found the source by googling: http://www.marxists.org/reference/archive/einstein/works/1910s/relative/ch07.htm I think the preceding sentence pretty much describes the idea. If c wasn't independent of the velocity of the source, then we'd see strange time-lags in observations of an eclipsing binary, since one star is approaching us while the other is receding.
Hello bcrowell,
That's the correct quotation. The book is simply called Albert Einstein: Relativity. You are referring to the sentence:
"At all events we know with great exactness that this velocity is the same for all colours, because if this were not the case, the minimum of emission would not be observed simultaneously for different colours during the eclipse of a fixed star by its dark neighbour"
I guess I am a little confused with this concept. I understand the part that if the colours had different velocities we should seem the colours arrive at different times (which is not the case obviously), but how does the eclipse of a fixed star by its dark neighbour have to do with explaining this concept?
Take a look at the graph and animation here:
http://en.wikipedia.org/wiki/Eclipsing_binary_star#Eclipsing_binaries
If different photons had different velocities, then they would all take different amounts of time to reach us. The graph would get scrambled and distorted.
Yes, I know see it. Truly amazing. The graph simplified everything for me.
Thank you bcrowell. Please let me know if there is anything you need. You helped me a lot. :)
PS: I wonder if an experiment could be done in the lab to show students.
The earliest experiment of that sort, I guess, should be Michelson-Morley, stating that though sources are moving with the earth, speed of light doesn't change.
But in the MM experiment, the source and the receiver are at rest relative to one another.
That's the DeSitter-double-star-experiment, which rule out the emission (or ballistic) theory of light, in which the speed of light depends on the velocity of the source, and in which light acts like a cannon ball:
http://en.wikipedia.org/wiki/De_Sitter_double_star_experiment
http://en.wikipedia.org/wiki/Emission_theory
While the Michelson-Morley experiment is compatible with Emission theories, there are many other experiments refuting this model, for example the Sagnac effect. It shows, that the speed of light is independent of the motion of the Sagnac interferometer, that is, while the source/receiver is moving, the light path becomes longer for one beam, and shorter for the counter-propagating beam. According to emission theory, this effect shouldn't exist.
So all of those experiments confirm special relativity, and refute emission theories. See also
http://math.ucr.edu/home/baez/physics/Relativity/SR/experiments.html
http://en.wikipedia.org/wiki/Tests_of_special_relativity
Regards,
  • · Replies 58 ·
9K
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 60 ·
13K
  • · Replies 40 ·
