How double glasses window reflect ?
  • Context: Undergrad
  • Thread starter Thread starter vkash
    Window
The discussion revolves around the phenomenon of reflection observed in double glass windows of train compartments, particularly when the train is underground or near a wall. Participants explore the reasons behind the visibility of reflections in these conditions compared to when the train is at a station with abundant external light.
  • One participant notes that reflections are visible on the glass windows when the train is underground due to the absence of external light, allowing internal light to be reflected back.
  • Another participant suggests that the double glass design helps in maintaining temperature but also contributes to the reflection observed.
  • It is proposed that reflections occur when there is an obstacle (like a wall) behind the glass, which can reflect light back towards the observer.
  • Some participants agree that when there is a lot of light from outside, the transmitted light dominates, making reflections less noticeable.
  • One participant references the Fresnel equations as a potential resource for understanding the behavior of light at the glass interface.
While some participants express agreement with the initial explanations regarding reflections, there is no consensus on the complete understanding of the phenomenon, and further opinions are sought to confirm the ideas presented.
Participants mention limitations in their ability to experiment with double glass windows, which may affect the depth of their understanding and the conclusions drawn.
This discussion may be of interest to those studying optics, physics enthusiasts, or individuals curious about light behavior in different environments.
vkash
Today when i was traveling in train(from my study center to home) i found a common but unexplained thing that is a little reflection can be seen on Glass window of train when it is underground or there is any wall behind the windows BUT when there is no window(ex when it is in station there is a lot of light) then i can't see any kind of reflection in window (or very very little reflection). I had read very little on Optics like Lens maker formula etc. I try to explain this during my 30 minute journey but i can't so i want to know it's answer from you why there is reflection in glass window.why this glass window was reflecting when it was underground. This glass window was double(one plate of glass after other as i see) i think because they(manufacturer of train) do this to don't make it hot due to sun in summer/ keep train cool with it's AC.One thing i also want to say that there a lot of lights inside train as a source of light for reflection.
How I explain it.[/color]
first explanation::-> This reflection happen due to reflection backward wall. Limitation wall did not reflect.
second explanation ::-> Double glass window of train reflect light rays every time but i can see them only at that time when there is any obstacle that does not overcome the intensity of light of reflected rays by glass window in case of stations there is light entering inside train which overcome the intensity of reflected light by glass window but when it is underground no light enter externally so i can see reflection of persons inside train. this idea has recently came in mind is it correct? Or there is any other explanation for this?
there is no double glass window in my house or nearby to experiment so you tell me.
Science news on Phys.org
It looks like you have the right idea. Glass will always reflect part of the light that strikes it and will always transmit some of that incident light.
If there is no light coming from outside the train, the only light you will see from the window will be light from inside reflected back to you. If there is a lot of light outside, the light coming from the window will consist mostly of outside light transmitted through the window with a relatively small amount of light reflected back from the inside, so the reflected light will be hard to distinguish.
AM
AM
:smile:Thanks Andrew.:smile:
I was excepting that there will many replies for this question but Here is only 1.:zzz:
I need more replies to confirm it 100% so please post your opinion guys!.:approve:
  • · Replies 25 ·
