Induced EMF in Non-Uniform Magnetic Field
The discussion revolves around the induced electromotive force (emf) in a square wire loop moving through a non-uniform magnetic field. The loop's dimensions and the magnetic field's orientation and strength are specified, along with the loop's velocity. Participants explore the implications of the loop's position relative to the magnetic field and the resulting induced emf.
  • Participants discuss the use of formulas such as E=Blv and the concept of motional emf. There are questions about how to determine the polarity of induced emf and the effects of the magnetic field on different parts of the loop as it moves through the field.
Some participants have provided guidance on using the force on a charge in a magnetic field to determine the direction of induced emf. Others express confusion about the calculations and the relationship between magnetic flux and induced emf, indicating a lack of consensus on the approach to take for specific cases.
Participants mention the need for a diagram to better understand the problem setup. There are also references to the complexity of the situation due to the loop's movement through areas of varying magnetic field strength.
arl146
A square wire loop of dimensions L X L (L = 15.5 cm) oriented in the xy-plane and centered on the x-axis enters a region where the magnetic field (B = 0.855 T) is first oriented in the +z- and then in the -z-direction as shown in the diagram below. (Note: W = 15.501 cm and the magnetic field is zero outside the shaded area.) The loop moves at speed v = 4.55 ms in the +x-direction. In the questions that follow, when asked for the emf, a positive emf will be defined as an emf induced counterclockwise (if viewed from above the loop); and vice versa.
(i.) What is the induced emf in the loop when the center of the loop is at x = -W?
(ii.) What is the induced emf in the loop when the center of the loop is at the origin?
(iii.) What is the induced emf in the loop when the center of the loop is at x = +W/2?
(iv.) What is the induced emf in the loop when the center of the loop is at x = +W?
See below
I think if I get help on one of them, then I should be able to figure out the others.
I'm not too sure how to approach this one, but I was thinking to use E=Blv or the flux=BA equation. But I'm not sure how that works out
no one can help me with this ? =/
still looking for help ...
In general emf = vBL for these sorts of situations but a drawing would be nice.
As WatermelonPig said, EMF=vBl
and its polatiry can be found out by F=q vXB (cross product)
bt we need a diagram to understand the question
Oh, sorry, wasnt paying attention that I didn't have one attached!
(i) when center will be at x=-w ... which part of loop will be inside mag. field area and which part will induce emf (for this, you should have studied motional emf)
only half of the loop will be inside the magnetic field that is pointing up. the left side half isn't in a B field. So just the right side that's in the magnetic field induces emf?
yes, that's correct :)
so, what does that mean haha i still am not sure what to do for it
you did first
now for second, you need to find polarity of induced emf in on the 2 wires (left and right) of loop ...
for this use the formula of force on moving charge in mag. field, [itex]\vec{F} \ = \ q \ \vec{v} \times \vec{B}[/itex]
As you would know, the wire moving in mag. field will act like a battery with a (+) and a (-) pole.
suppose there is a positive charge in wire moving with wire ... find direction force on it (generally along wire in these kind of questions). the side where + charge moves is (+) and other is (-)
thus find net emf in wire in case (ii)
so wait .. i don't get it, how did i do the first one?
and for (ii.) how do you use that without q ?
Since you're dealing with a loop, it would be more straightforward to calculate the rate of change of the magnetic flux through the loop to find the emf.
motional EMF in a wire moving in mag field is vBL , here v is velocity B is mag field and L is the length.
i did that already it was wrong
is it sign problem or magnitude is wrong?
Oh wait, I got it now :)
Okay, for the second: i don't get what youre saying for that ..
Can I please have some help on the other one's then?
do you know how to find polarity of the charges in a wire?
i don't think ... I am not too sure what that means
When a wire will move in mag. field, EMF will be induced in it.
so there will be a current flowing in wire and thus one end will get positive charge and other negative.
Can you find which end will get which charge?
.. i have no idea?
you know of formula for force on a charge in magnetic field ... F = q (v X B)
lets suppose there is a positive q charge inside the wire ... This charge will feel a mag. force when wire is moving ... find the direction of this force ... q will move in direction of Force and the side of wire where it moves will get (+) and other (-)
wouldnt the force just be in the direction opposite of the motion, so. then the left side would be positive and the right side would be negative
is that right?
Can someone help with this problem as well? =/ I am lost
I actually just need help on the second one. I got the rest!
Let x be the position of the front end of the loop. What's the flux through the loop in terms of B, L, and x?
I actually just got it ! It was twice my first answer but positive. I'm not too sure why it was twice, could you explain that?
You're the one who's supposed to be able to explain how you got the answer!
  • · Replies 41 ·
9K
