Efficiently Simulating N Particle Systems in FORTRAN: Tips and Tricks
  • Thread starter Thread starter morenogabr
    Particle System
This discussion focuses on efficiently simulating N particle systems in FORTRAN, addressing how to declare and manage particle data without excessive WRITE statements. Users are advised to utilize a linked list data structure to handle an arbitrarily large number of particles, as arrays are insufficient. The conversation also highlights the importance of data formatting for visualization, suggesting that data be written in a comma-separated or tab-separated format for compatibility with programs like Excel.
  • FORTRAN programming, specifically FORTRAN 90 or later
  • Understanding of data structures, particularly linked lists
  • Basic knowledge of file I/O operations in FORTRAN
  • Familiarity with data visualization tools, such as Excel
  • Research linked list implementation in FORTRAN for dynamic particle management
  • Learn about FORTRAN file I/O techniques for efficient data writing
  • Explore data formatting options for compatibility with visualization tools
  • Investigate advanced FORTRAN features for performance optimization in simulations
Researchers, physicists, and programmers working on simulations of multiparticle systems in FORTRAN, as well as anyone interested in optimizing data management and visualization in scientific computing.
morenogabr
When simulating N particles in FORTRAN:
- How do I declare x,y,z,vx,vy,vz for arbitrarily large number of particles N?
- How do I write out data for each particle without N write statements?
I intend to have a time-step do loop with a particle do loop inside so that at each time step I cycle through each particle, do the computation, and update the data.
Writing numerical data for multiparticle system
I am simulating a multiparticle system using FORTRAN language. But my question is a general programming question regarding how to write data.
I am using a loop to cycle through a number of particles, and running a numerical computation and writing out data at each time step. So a particle loop with a time loop inside of it so that each particles trajectory over all time is calculated one particle at a time.
My question is simply:
-How can I use the loop index referring to the particle in a WRITE statement so that for each particle I open a new data file, without having to create a WRITE statement for each particle individually?
-Would it be easier to write all the data into one data file, just having the write statement tab over after each particle or something like that?
Theoretically, I need to be able to take that data file to a graphics program and visualize it from raw data. No GUI.
I'll answer in general terms, since it's been forever since I programmed in FORTRAN.
You cannot use an array for an "arbitrarily large number of particles". You would need to create a datastructure like a linked list, which you can grow and shrink as needed.
What "No GUI" graphics program do you intend to use to visualize the data? That will start to determine what format you use when you write out the data.
You could use something as simple as Excel to visualize the data, if you write it out as comma-separated or tab-separated data, one line of data (for all of the particles) per time slice.
