Register to reply
Converting velocity to pressure
by ssavader
Tags: converting, pressure, velocity
Share this thread:
ssavader
#1
Jul8-11, 09:26 PM
P: 3
I am trying to work with the simplified Bernoulli equation to determine how to convert a drop in flow velocity across a stenosis (narrowing) into a change in hemodynamic pressure. Radiologists often use Doppler ultrasound to measure flow velocity change in a blood vessel with a stenosis- but I would like to make a conversion to a pressure differential.
Equation: P2-P1 = (V2^2 - V1^2)/2 (assuming frictionless system, blood density ~ 1.0 gm/cm^3, and no change in height)
P2-P1 = [(126 cm/sec)^2 - (90 cm/sec)^2]/2 (^ symbol= raise to power of)
Can someone show me how to convert the units of (cm/sec)^2 to mmHg? Or show me where my error in thinking is?
Thank you kindly,
Scott
Phys.Org News Partner Physics news on Phys.org
New complex oxides could advance memory devices
Nature's designs inspire research into new light-based technologies
UCI team is first to capture motion of single molecule in real time
boneh3ad
#2
Jul8-11, 10:12 PM
PF Gold
boneh3ad's Avatar
P: 1,509
Convert to m/s and then carry out the computation and your answer will come out in Pascals. Then convert Pascals to mmHg using whatever Google says the conversion factor is.
ssavader
#3
Jul8-11, 10:52 PM
P: 3
Help me out please: Is 126 cm/sec x 126 cm/sec = 15826 cm/sec or cm squared/sec squared? I know this is basic but its been a few decades since my last physics class!
Also, I am unsure if you are implying that m/sec x m/sec can be converted to pascals. I can't find a calculator to do this conversion?
cjl
#4
Jul9-11, 12:51 AM
P: 1,027
If you do everything in standard SI, your answer will come out in Pa. You're forgetting to include the units of density (which will need to be in kg/m3, so you should use 1000 rather than 1 for that). As for the units of V2? It should be m2/s2. So, for your specific numbers, it should be:
P2-P1 = [(1.26 m/s)2 - (0.90 m/s)2]*1000 kg/m3/2
If you work through the units, you will find that it does in fact come to be pressure (specifically pascals) when done this way.
(Specifically, the units are m2/s2*kg/m3, which can be rearranged into (kg*m/s2)/m2, which becomes N/m2, which is a pascal)
ssavader
#5
Jul9-11, 11:04 AM
P: 3
cjl, thank you so much. Now it all makes sense.Ii really appreciate the time you invested in my question. Once I get the answer in Pascals, I can then use a converter to change to Torr, or "mmHg", which is how blood pressure is measured.
Register to reply
Related Discussions
Converting Pressure to Energy Engineering Systems & Design 25
Converting angual velocity to linear velocity Introductory Physics Homework 3
Converting Pressure into Heat Classical Physics 23
Converting Acceleration to Velocity Introductory Physics Homework 9
Converting pressure to flow rate Introductory Physics Homework 4
