PHysics PHysics Physics Physics Torque
  • Thread starter Thread starter envscigrl
    Physics Torque
The discussion focuses on calculating the torque acting on a 2.50g particle moving in a circle with a radius of 3.00m, given that its angular momentum L varies with time as L = (3.5 Nm)t. The correct approach involves using the relationship between torque and angular momentum, specifically that torque (T) equals the rate of change of angular momentum. By applying the formulas T = r x F and L = Iω, the final calculation reveals that the magnitude of the torque acting on the particle is 1.17 N.
  • Understanding of angular momentum and its relation to torque
  • Familiarity with the moment of inertia formula, I = mr²
  • Knowledge of circular motion dynamics
  • Proficiency in algebraic manipulation of physics equations
  • Study the relationship between torque and angular momentum in rotational dynamics
  • Learn about the moment of inertia for different shapes and mass distributions
  • Explore the concept of angular velocity and its calculations
  • Investigate the applications of torque in real-world mechanical systems
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in understanding the principles of torque and angular momentum in circular motion.
envscigrl
Here is my problem:
A 2.50g particle moves in a circle of radius 3.00m. The magnitude of its angular momentum relative to the center of the circle depends on time according to L = (3.5 Nm)t. Find the magnitude of the torque acting on the particle.
I know that:
T = F L
where T = torque
F is the force
L is angular momentum
I feel like this problem is more algebraic than anything. I just need something stable to start from. Pleeeeeeeeaaaase Heeeeeeelp!
I'm afraid your equation is wrong. You may be thinking of [tex]\vec{\tau} = \vec{r}\times\vec{F}[/tex], where r is the moment arm (and its a vector equation). What you need to use is the idea that the rate of change of angular momentum is equal to the torque. I hope that helps.
Hi there,
To solve this problem, we can use the formula T = r x F, where r is the radius of the circle and F is the force acting on the particle. We can also use the formula L = Iω, where I is the moment of inertia and ω is the angular velocity.
First, let's find the angular velocity of the particle. We can rearrange the formula for angular momentum to get ω = L/I. Since the particle is moving in a circle, its moment of inertia can be calculated as I = mr^2, where m is the mass of the particle and r is the radius of the circle. Plugging in the given values, we get I = (2.50g)(3.00m)^2 = 22.5 g m^2.
Now, we can plug in the given values for angular momentum and moment of inertia to find the angular velocity: ω = (3.5 Nm)/(22.5 g m^2) = 0.1556 Nm/g.
Next, we can use the formula for torque to find the force acting on the particle: T = r x F. Rearranging this formula, we get F = T/r. Plugging in the values of torque (3.5 Nm) and radius (3.00m), we get F = 3.5 Nm/3.00m = 1.17 N.
Therefore, the magnitude of the torque acting on the particle is 1.17 N. I hope this helps! Remember to always pay attention to units and use the correct formulas when solving physics problems. Good luck!
  • · Replies 35 ·
  • · Replies 17 ·
18K
