Too easy and wrong: consv of angular momentum
The discussion centers on a physics problem involving the conservation of angular momentum and kinetic energy. A man standing on a frictionless rotating platform with an initial angular speed of 1.60 rev/s experiences a change in moment of inertia from 6.30 kg m² to 2.30 kg m² after pulling weights inward. The resulting angular speed is calculated using the formula Ii * wi = If * wf, leading to a final angular speed of 6.93 rad/s. The change in kinetic energy is determined to be 553.7 J, highlighting the importance of unit conversion in angular speed calculations.
  • Understanding of angular momentum conservation principles
  • Familiarity with moment of inertia calculations
  • Knowledge of kinetic energy formulas in rotational dynamics
  • Ability to convert angular speed units (rev/s to rad/s)
  • Study the derivation of the conservation of angular momentum equation
  • Learn about the relationship between moment of inertia and angular speed
  • Explore advanced kinetic energy calculations in rotational systems
  • Practice unit conversion techniques for angular measurements
Students and educators in physics, particularly those focusing on mechanics, as well as anyone interested in understanding rotational dynamics and energy conservation principles.
envscigrl
Here is my problem:
A man stands at the center of a platform that rotates without friction with an angular speed of 1.60rev/s. His arms are outstretched, and he holds a heavy weight in each hand. The moment of inertia of the man, the extended weights, and the platform is 6.30 kg m2. When the man pulls the weights inward toward his body, the moment of inertia decreases to 2.30 kg m2. What is the resulting angular speed of the platform? ( Give answer in rad/s)
I got this first part using conservation of Angular momentum or:
Ii *wi = If *wf
and then I converted of course.
It then asks :
What is the change in kinetic energy of the system?
I thought finding this answer would be easy but I can't seem to get it.
I tried using KE = .5 I w^2
and finding the KE for before and after the arm extension and then subtracting. I guess that was too easy because it was wrong!
Thanks for the help guys (and gals hopefully!)
The method is correct though.
What'd you get? I got a difference of 553.67 J.
I swear I must have tried that problem a milllion different times last night but I just couldn't get it. When I tried again I got the right answer (553.7). I wasnt converting the angular speed from the first answer back into rev/s. Thanks so much for your help!
18K
  • · Replies 18 ·
