CMBR anisotropies, FAQ, & universal rotation (kind of)
The discussion revolves around the concept of cosmic microwave background radiation (CMBR) anisotropies and their implications for universal rotation. Participants explore the mathematical and conceptual aspects of these anisotropies, questioning assumptions about observer positioning and the nature of rotation in cosmological models.
  • One participant seeks references that focus on the meaning of CMBR anisotropies rather than specific calculations, expressing difficulty in understanding the mathematical details.
  • Another participant notes that general relativity allows for rotation without a defined center, suggesting that the assumption of being at the center is not necessary in these models.
  • A participant references a paper that assumes the observer is on the rotating axis, questioning the validity of this assumption in light of the homogeneous principle.
  • Further clarification is provided that Barrow's model is homogeneous, lacking a specific position for the axis of rotation, while Su's model can be either homogeneous or inhomogeneous.
  • It is pointed out that the assumption of being on the axis of rotation in some models is made for computational convenience, and that generalizations exist for cases where the observer is off-axis.
  • Homogeneity is discussed as an approximation that can be broken, particularly in the context of inhomogeneous models, which may lead to CMB anisotropies.
Participants express differing views on the assumptions regarding observer positioning and the implications of homogeneity in cosmological models. There is no consensus on these points, and the discussion remains unresolved.
Participants highlight limitations in understanding the assumptions made in various models, particularly regarding the positioning of observers and the implications for CMBR anisotropies. The discussion reflects a range of interpretations and assumptions that are not universally accepted.
Lino
There have been many posting (questions and answers) on universal rotation and there is a fine posting with references on the FAQ. Thanks to everyone for these. I don't pretend to understand the detail (especially of the maths), but I do understand most of the principles. However, there is one element that I am having difficults with and would appreciate any pointers / references that might help.
The articles / references on the use of CMDR anisotropies to limit (potential) rotation, contain a lot of maths, and (I think) focus on the calculations of various aspects (rather than the type / meaning of the anisotropies). Can you recommend any references / articles that discuss the anisotropies, rather than focus on specific calculations?
On a slightly different note, from the articles / papers that I have read, (I think that) there is a general assumption that we (the observer) are positioned on, or close to, the axis of rotation / origin, in comparison to the distance to the edge / source of the CMBR. This strikes me as a very dangerious assumption (it just doesn't seem to be consistent with the homogeneous principle). Am I missing something here?
Thanks inanticipation,
Noel.
Space news on Phys.org
General relativity allows rotation without a center of rotation. In these models, there is no center of rotation. So not only is there no assumption that we're at the center, there isn't even any center.
Ben,
Thanks for responding and this is what I thought aswell. I am obviously missing / mis interputing something, and maybe you can enlighten me! The below quote is from a paper by Shi Chun / Su / CHu entitled Is the Universe Rotating - 2009 (text from below equation B6 in appendix II).
[... For simplicity, we assume that we are located on the rotating axis. Therefore, ηλ = λ and rλ = −λ sin φ due to the cylindrical symmetry. Although the general case that we may be off the rotating axis is more realistic, the constraint here can be regarded as a good approximation provided that our distance to the rotating axis is small compared to that of the last scattering surface. ...]
I don't know how else to read this, but I thought that the / your answer might help me understand the 'shape' of the rotation.
Regards,
Noel.
I see. I obviously didn't read the paper carefully enough. Thanks for pointing this out!
The two papers that I'm aware of that try to calculate observational constraints on the rotation are these:
Barrow, Juszkiewicz, and Sonoda, "Universal rotation: how large can it be?," Mon. Not. R. Astr. Soc. 213 (1985) 917, http://adsabs.harvard.edu/full/1985MNRAS.213..917B
Su and Chu, "Is the universe rotating?," 2009, http://arxiv.org/abs/0902.4575
Barrow's model is homogeneous, so there is no position for the axis of rotation, only a direction for the axis of rotation. Su's can be either inhomogeneous or, as a special case, homogeneous (p. 4).
Re this point...
...my original reply was wrong. However, I also don't think you've interpreted it correctly. There can be both homogeneous models, like Barrow's or the homogeneous special case of Su's, and inhomogeneous models, like Su's general case, so there is no general assumption throughout the literature that there is inhomogeneity. When Su and Chu consider the general inhomogeneous case, they explicitly consider effects that can arise if we're off axis (see p. 8). The part of Appendix II that you quoted is talking about an assumption made purely for the sake of computational convenience, and immediately afterward they discuss how to generalize it to the case where we're not on axis.
Homogeneity is broken by the general case of Su and Chu's model. It's broken regardless of whether the observer is on axis or not. Homogeneity is only an approximation. If it were a perfect approximation, there would be zero CMB anisotropy.
Thanks again Ben. The ' I also don't think you've interpreted it correctly' is exactly what I expected ... although I can't pretend to understand the details ... yet!
I'll keep trying to working through that, but if you do come across any discussions (rather than calculations)on the CMBR anisotropies, I would much appreciate it if you could let me know.
Regards,
Noel.
  • · Replies 20 ·
  • · Replies 47 ·
  • · Replies 25 ·
  • · Replies 19 ·
