Introduction to Group Field Theory: Main Ideas, Formalism, and Origins
The discussion revolves around the concepts and formalism of Group Field Theory (GFT), including its foundational ideas and the nature of fields defined on Lie groups. Participants explore the relationship between groups and spaces, and the implications of defining fields in this context.
  • Some participants propose that ordinary fields are defined on standard spatial coordinates, while GFT fields are defined on Lie groups like SU(2) or their Cartesian products.
  • One participant questions whether a group can be considered a "space" akin to ordinary coordinate systems, drawing parallels to Hilbert spaces.
  • Another participant describes GFT as a finite simplification of space represented by a graph of nodes and links, where geometry is defined by Lie-group labels on these links.
  • A participant suggests that functions defined on the product of Lie groups can be viewed as quantum states of geometry, analogous to wavefunctions but in the context of geometrical configurations.
  • There is mention of the need to consider technical aspects like square integrability and redundancy in defining a Hilbert space for these functions.
  • One participant asserts that a Lie group is a topological manifold, allowing for local coordinate patches similar to other topological spaces.
Participants express varying views on the nature of groups as spaces and the implications for GFT. There is no consensus on the foundational aspects of GFT or the interpretation of groups in this context, indicating ongoing debate and exploration.
The discussion includes assumptions about the nature of fields and geometries in GFT, as well as the mathematical properties of Lie groups. Some technical details remain unresolved, particularly regarding the transition from finite to infinite degrees of freedom in the theory.
Schreiberdk
Hi there PF
I just want to ask, what are the main ideas behind Group Field Theory? How does it work, and what is the formalism? And why is it called GROUP Field Theory? :)
\Schreiber
ordinary fields are functions defined on the ordinary x-y-z coordinates of flat space.
what values the functions take does not matter for this discussion. they might be real number valued, or complex number vaued, or vector valued etc.
what matters is the domain of definition.
suppose instead of being defined on the ordinary xyz coords of flat space, or txyz coords of flat 4D the fields are functions defined on a Lie group like SU(2).
Or some other Lie group, call it G.
Or on a cartesian product of N copies of G. Like GxGxG...xG.
Then it is a group type of field theory.
That really makes quite good sense, except: Does a group form a "space" in the same way ordinary coordinate-systems does (sort of the same way a Hilbert space works)?
\Schreiber
\Schreiber
Other people may answer that question differently. Here is how I think of it.
In GFT you think of a finite simplification of space that is just a graph of nodes and links.
a finite set of locations joined by paths.
and a GEOMETRY is a set of Lie-group labels on the links that say what happens to you when you move along the link. do you get rotated? if so how? What transformation happens to you as you run from this place to that place?
so a point in GxGxG...xG is an N-tuple of group elements which label the graph and determine its shape (a "position" in the space of all shapes that graph could have, or a "configuration" of the graph)
so a FUNCTION defined on GN is like a WAVEFUNCTION for a particle. except that instead of being defined on the real line, on the possible positions of the particle, it is defined on the space of possible geometries of this simplified N-world, this graph with N links.
Or let me not say wavefunction, let me call it a quantum state of geometry.
I am talking very loosely.
anyway the functions defined on GN make a HILBERTSPACE. There are some technicalities like making sure they are square integrable, and factoring out some redundancy. (Two N-tuples can describe the same experience of running around in the graph if they are offset copies of each other in a certain sense.)
Then you have to take the limit as N --> ∞
But instead of taking the limit, let us just think of this finite world of the graph, and its geometry. A truncation of the infinite degrees of freedom that realworld geometry has. (or maybe it doesn't really). So keep N finite.
Then GN = GxGx...xG is like the world of geometries, the geometric possibilities.
So instead of doing field theory on space time = txyz
we do field theory on the world of possible configurations = GN.
This is a sloppy impressionistic introduction. Someone else can perhaps improve.
There is a Loops 2011 talk by Dan Oriti on GFT. The video should be available.
http://www.iem.csic.es/loops11/
A more direct link:
http://loops11.iem.csic.es/loops11/...velopments&catid=35:plenary-lectures&Itemid=1
(This was a template I got from Unusualname: &view=article&id=76%3Acarlo-rovelli-the-covariant-version-of-loop-quantum-gravity-definition-of-the-theory-results-open-problems&catid=35%3Aplenary-lectures&Itemid=1
which can be used to construct direct links.)
Schreiberdk said:
Does a group form a "space" in the same way ordinary coordinate-systems does?
A Lie group is a topological manifold, so locally you can introduce coordinate patches as for any other topological space. Think about the Euler rotations angles as coordinates for SO(3).
  • · Replies 26 ·
  • · Replies 0 ·
