Strangely difficult log question
  • Thread starter Thread starter Coldie
    Log
The problem involves solving the equation 485 + 5^(x + 2) = 12^(2x - 1), which presents challenges due to the presence of the variable in both the exponent and as part of a sum. Participants express frustration and confusion regarding the appropriate methods to approach the problem, particularly in relation to logarithmic properties.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the necessity of reducing both sides to a single expression before applying logarithms. Some suggest numerical approximation methods, while others mention the Lambert W function as a potential avenue for exploration. There is also a debate about the validity of taking logarithms directly due to the structure of the equation.
The discussion is ongoing with various interpretations being explored. Some participants have offered insights into potential methods, while others express skepticism about the problem's difficulty level, suggesting it may not align with the expected curriculum. There is no explicit consensus on a single approach yet.
Participants note that the problem appears in a Math 12 textbook, raising questions about its appropriateness for the intended audience. There is also mention of potential typos or errors in the problem statement, contributing to the confusion.
Coldie
485 + 5 ^ (x + 2) = 12 ^ (2x - 1)
This question is driving me nuts. I can't take the log until both sides have been reduced to one expression each, right? If 485 were a power of 5 or 12, then I'd be able to solve it. As it is, I'm clueless. Can someone walk me through the steps to solving for x?
And if you can't help me there, could you please tell me how to use those nifty image-generating tags for mathematical expressions?
I think you will have to resort to a numerical approximation.
There is no elementary formula for an exact solution of an equation in which the variable appears both in the exponent and not in the exponent. You might try looking at "Lambert's W function".
It's defined as the inverse to f(x)= xex.
Here's a link to the "MathWorld" page on it:
http://mathworld.wolfram.com/LambertW-Function.html
I just looked at this again and noticed that both occurences of "x" ARE as exponents. The difficulty is really taking the logarithm of a sum. Yes, a numerical method is necessary here.
Wow, thanks for the help. I'm beginning to think that this is a typo... the question appears in a Math 12 book on a chapter introducing logs, so I doubt it should be THIS hard.
I may be missing the point, but..
Take the natural logarithm of both sides:
[tex]485 + 5^{(x + 2)} = 12^{(2x - 1)} \Rightarrow \ln(485)+(x+2)\ln(5)=(2x-1)\ln(12)[/tex]
Which is a simple linear equation. The unknown only appears in the exponent.
Unfortunately [tex]\ln(485 + 5^{(x+2)})[/tex] != [tex]\ln(485)+(x+2)\ln(5)[/tex] so your solution isn't quite correct.
Unfortunately, I have these moments often after a day of abstract algebra.
I'm going to lie down now... :zzz:
  • · Replies 29 ·
  • · Replies 16 ·
  • · Replies 27 ·
