Solving Infinite Series Problem with L'Hopital's Rule
The discussion revolves around an infinite series problem involving limits and L'Hopital's rule. The original poster presents a limit expression and expresses confusion regarding the application of L'Hopital's rule and the resulting derivatives.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the application of L'Hopital's rule and alternative algebraic manipulations, such as dividing the numerator and denominator by n. Questions arise about the validity of using L'Hopital's rule in this context, particularly regarding the nature of n as an integer.
Some participants have provided guidance on algebraic manipulation, while others question the appropriateness of L'Hopital's rule for this problem. The discussion reflects a mix of interpretations and approaches without reaching a consensus.
There is a mention of a technical distinction between "sequences" and "series," which some participants clarify, indicating a potential misunderstanding in terminology related to the problem.
kdinser
Today we started on infinite series, I'm getting the material just fine and able to do most of the problems, but one is giving me problems.
[tex]\lim_{n\to{a}} 2n/\sqrt{n^2+1}[/tex]
I recognized that [tex]\infty/\infty[/tex] so I can use L'Hopital's rule. So taking the derivative of the numerator and denominator I get.
[tex]\frac{d}{dn} 2n = 2[/tex]
and
[tex]\frac{d}{dn} \sqrt{n^2+1} = \frac{n}{\sqrt{n^2+1}}[/tex]
Somehow the solutions manual is getting
[tex]2/\sqrt{1+(1/n^2)}[/tex]
and a final answer of 2.
I can't see how they turned what I get for the derivative in the denominator into what they use. L'Hopital's rule twice would get rid of the n on top and put a 2 there, but that wouldn't change the square root.
thanks for any help
Simply divide the numerator and the denominator by n. You get:
[tex]\frac{2n}{\sqrt{n^2+1}}=\frac{2}{\sqrt{1+1/n^2}}[/tex]
I'd advise against using l'hospitals rule. Although it may be valid to use in some cases, you generally have to show it actually is.
In this case, n is restricted to integer values so the derivative doesn't exist.
Thanks for the help,
Could you go through a little of the algebra in the denominator, it's still not making sense to me how it's actually done. What property allows you to divide the radical by n and come up with that?
Doh, nevermind, it popped into my head as I was taking a shower. Thanks again.
By the way, in mathematics, there is a technical difference between "sequences" and "series". What you are dealing with here are "series", not "sequences".
Haha, not the other way around? :-p
Don't confuse them indeed. :wink:
  • · Replies 21 ·
