Work and Energy Formula Help: Air Resistance
The discussion focuses on calculating the work done by air resistance on a basketball during a jump shot. Using the work-kinetic energy theorem, the work done by air resistance is determined to be approximately 0.52 Joules. The force of air resistance is calculated with the formula F = 0.5 * p * v^2 * A, resulting in a force of 0.353 Newtons. The distance traveled by the ball is found to be 1.47 meters, leading to the final work calculation.
  • Understanding of the work-kinetic energy theorem
  • Knowledge of air density and its impact on force calculations
  • Familiarity with basic physics formulas for force and work
  • Ability to perform calculations involving velocity and area
  • Explore the implications of nonconservative forces in physics
  • Learn about the effects of air resistance on projectile motion
  • Investigate different methods for measuring air density
  • Study the principles of energy conservation in sports physics
Physics students, sports scientists, and anyone interested in the dynamics of projectile motion and the effects of air resistance on moving objects.
Bcisewski
Formula assistance, can anyone assist?
A basketball player makes a jump shot. The 0.534-kg ball is released at a height of 2.01 m above the floor with a speed of 8.95 m/s. The ball goes through the net 3.48 m above the floor at a speed of 4.87 m/s. What is the work done on the ball by air resistance, a nonconservative force?
Help yourself with
Work-Kinetic energy theorem
[tex]\sum_{i=1}^{n} W_{i} = \Delta K[/tex]
To calculate the work done by air resistance, we can use the formula W = Fd, where W is the work done, F is the force of air resistance, and d is the distance traveled by the ball.
First, we need to find the force of air resistance. This can be calculated using the formula F = 0.5 * p * v^2 * A, where p is the density of air, v is the velocity of the ball, and A is the cross-sectional area of the ball.
Assuming a density of air of 1.2 kg/m^3 and a cross-sectional area of the ball of 0.03 m^2, we can calculate the force of air resistance as follows:
F = 0.5 * 1.2 kg/m^3 * (4.87 m/s)^2 * 0.03 m^2
= 0.353 N
Next, we need to find the distance traveled by the ball. This can be calculated by subtracting the initial height from the final height:
d = 3.48 m - 2.01 m
= 1.47 m
Now, we can plug in our values into the work formula:
W = Fd
= (0.353 N)(1.47 m)
= 0.52 J
Therefore, the work done by air resistance on the basketball is approximately 0.52 J. This means that the air resistance has slowed down the ball's motion and caused it to lose some of its energy.
  • · Replies 16 ·
9K
  • · Replies 19 ·
