Understanding Point Charges Along a Uniformly Charged Line
  • Context: Undergrad
  • Thread starter Thread starter tripsynth
This discussion focuses on understanding the electric field intensity at a point P due to a uniformly charged line, as described in "Electromagnetism" by John C. Slater and Nathaniel Frank. The term r/R is identified as equivalent to the cosine of the angle formed between the line charge and the point P. The analysis emphasizes that the electric field components parallel to the x-axis cancel out due to symmetry, while the components along the y-axis contribute to the net electric field at point P, which is positioned at coordinates (0, r).
  • Understanding of electric field concepts
  • Familiarity with charge distribution and line charge
  • Knowledge of vector components in physics
  • Basic grasp of calculus for integration of charge elements
  • Study the derivation of electric fields from continuous charge distributions
  • Learn about the concept of line integrals in electromagnetism
  • Explore the application of Gauss's Law in calculating electric fields
  • Investigate the effects of symmetry in electric field calculations
Students of physics, particularly those studying electromagnetism, educators teaching electric field concepts, and anyone interested in advanced applications of charge distributions in physics.
tripsynth
Hi, I'm trying to understand point charges along a uniformly charged line with a charge per unit length. This is a screenshot of what I'm trying to understand. http://i.imgur.com/s1vX7.jpg
I am not sure where the term r/R is coming from. I realize that the r term in sigma*dx/4pi*enot should change as you go down the x-axis but I don't get where the factor r/R comes from. I feel like I'm missing something. This is an example page from the book "Electromagnetism" by John C. Slater and Nathaniel Frank.
They are only considering the component of the field perpendicular to the line of charge (the parallel component will add to zero for an infinite line of charge). r/R is equivalent to the cosine of the angle.
No, you are not trying to "understand point charges along a uniformly charged line"...you are trying to "understand the electric field intensity at point P which is at a distance r from a charge line".
You see, you are trying to determine the influence of the entire line charge (which is discretized in a bunch of little dx's) on a given point P.
If the x-axis is vertical and the y-axis is horizonatl and the charge line pretty much lies on the x-axis and the point P is at a coordinate (x,y)=(0,r)
The field intensity at P due to a given dx (x not equal 0) will be along the line the joins that dx and the P point, and hence, it can be thought of having two components, one parallel to the x-axis and one parallel to the y-axis...since the charge line is infinite long, the point P "sees" the same thing above it (x>0) as below it (x<0) and hence all the x-components of the field at P cancel out and all the y-components add up.
  • · Replies 18 ·
