Mass of trapped photons vs. Mass of potential energy
The discussion centers on the relationship between trapped photons and the mass of a system, specifically in the context of black holes and perfect-mirror containers. It is established that shining light on a black hole increases its mass due to the energy of the photons contributing to the black hole's mass. However, when considering a system with two heavy masses and a perfect-mirror-container filled with photons, the total mass remains unchanged. The energy that generates the photons originates from the gravitational field of the masses, resulting in a mass deficit that balances the mass gain from the photons.
  • Understanding of black hole physics and mass-energy equivalence
  • Familiarity with the concept of trapped photons and their energy contributions
  • Knowledge of gravitational fields and their effects on mass
  • Basic principles of binding energy and mass deficit
  • Read the Wikipedia article on binding energy, focusing on the mass deficit section
  • Explore the implications of mass-energy equivalence in general relativity
  • Investigate the behavior of photons in gravitational fields
  • Study the properties and applications of perfect mirrors in theoretical physics
Physicists, astrophysicists, and students interested in gravitational physics, black hole dynamics, and the interplay between energy and mass in complex systems.
cephron
I've understood for a while that a black hole is made more massive simply by shining light on it; the energy of the photons "goes towards" (for lack of a more informed/accurate term) the mass of the black hole. Also, a couple weeks back, someone on the forums said that if one had a container lined with perfect mirrors, then photons trapped inside the container would effectively add mass to the object. If this is true, then it occurred to me that a system could conceivably change its mass by sequestering photons within itself.
Imagine the following system: two heavy masses, at rest relative to each other, are held apart by a scaffold of some kind. The scaffold has a track which will allow the masses to fall towards each other, driving an electricity generator as they go. The generator is hooked up to a lamp which shines into a really, really long perfect-mirror-container, with another perfect mirror ready to slide down in front of the lamp (to close the container). Let's say the total mass of all the components of the system is M.
When this contraption is triggered, the masses fall towards each other, the lamp shines, and the mirror snaps shut before the light returns from the far end of the container. We now have the same system, with none of its particles missing, except now we also have a perfect-mirror-container full of photons.
Is the total mass of the system still M? Or is it slightly more? If the mass is the same, then where did the mass of the trapped photons "live" before they were generated?
Thanks in advance for any input / explanation / humbling rebuke.
Still M. The energy that made the photons came from the gravity field itself. The net far-field gravity is the same though the two masses have a quadupole moment that would be different for the box of photons.
The mass is the same. You should read the wikipedia article on binding energy, particularly the section on mass deficit. In this case the two masses are a more tightly bound system afterwards, so there is a mass deficit in the system. Assuming 100% efficiency everywhere that mass deficit is exactly equal to the mass gain from the photons.
  • · Replies 16 ·
  • · Replies 125 ·
  • · Replies 62 ·
  • · Replies 48 ·
