Calculating Square Tubing Dimensions for Vertical Bicycle Support
  • Thread starter Thread starter drianengelbre
    Dimensions Square
This discussion focuses on calculating the dimensions and thickness of square tubing required to support a load of six bicycles, each weighing 18 kg, suspended vertically. Key considerations include the spacing between bicycle centerlines (a2), the spacing between the inboard bicycle centerline and the vertical post centerline (a1), and the material specifications of the square tubing, including its tensile yield strength. Participants emphasize the importance of understanding these parameters to ensure structural integrity and safety in the design.
  • Understanding of load calculations in structural engineering
  • Knowledge of material properties, specifically tensile yield strength
  • Familiarity with square tubing dimensions and specifications
  • Basic principles of static equilibrium in mechanical systems
  • Research the tensile yield strength of various square tubing materials
  • Learn how to calculate load distribution for suspended structures
  • Explore design guidelines for bicycle support systems
  • Investigate software tools for structural analysis and design
Mechanical engineers, structural designers, and hobbyists involved in creating bicycle support systems or similar load-bearing structures will benefit from this discussion.
drianengelbre
I would like to know which calculations to use to determine the dimensions, including the thickness of square tubing that needs to carry a load of 6 bicycles each weighing 18kg. The bicycles are vertically suspended from the tubing and the support is in the middle of the tubing so the ends are free.
drianengelbre: (1) What is the spacing (a2) between each bicycle centerline? (2) What is the spacing (a1) between the inboard bicycle centerline and the vertical post centerline? (3) What is the square tubing material, and the material specification number, and tensile yield strength? (4) Is this a school homework problem?
  • · Replies 22 ·
19K
9K
  • · Replies 17 ·
  • · Replies 17 ·
12K
