Energy Required to Change Water into Steam
The energy required to change one-quarter of 8.0 kg of water at 25°C into steam is calculated to be 7.12 x 10^6 J. This calculation involves two steps: first, heating the entire 8.0 kg of water from 25°C to 100°C using the specific heat capacity of water (4200 J/kg°C), and then converting 2.0 kg of that water into steam using the latent heat of vaporization (2.3 x 10^6 J/kg). The calculations confirm that the methodology and results are accurate.
  • Understanding of specific heat capacity and its formula
  • Knowledge of latent heat of vaporization
  • Basic algebra for energy calculations
  • Familiarity with temperature units (Celsius)
  • Study the principles of thermodynamics related to phase changes
  • Learn about specific heat capacity calculations in different materials
  • Explore the concept of latent heat in various substances
  • Investigate practical applications of steam generation in engineering
Students studying physics or chemistry, educators teaching thermodynamics, and professionals in engineering fields focused on heat transfer and energy calculations.
Seinfeld4
How much energy is required to change one-quarter of 8.0kg of water at 25 C into steam?
The way I see it, the entirety of the 8.0kg of water must be brought from 25 C to 100 C, then only 2.0kg is changed to steam so...
Specific heat capacity (of water) = 4200 J / kg C
Latent heat of vaporization (of water) = 2.3 * 10^6 J/kg
Q total = (8.0kg) (4200 J / kg C) (100-25) + (2.0kg) (2.3 * 10^6 J/kg)
Q total = 7.12 * 10^6 J
I'm not 100% sure if I'm doing this properly. Does this look correct?
That looks correct to me!
Cool, thanks!
