New Reply
net gravitational force
Share Thread Thread Tools
Jul20-11, 04:54 PM   #1
the earth has a mass of 5.98 x 10^24 kg and the moon has a mass of 7.35 x 10^22 kg. the distance from the centre of the moon to the centre of the earth is 3.84 x 10^8m. a rocket with a total mass of 1200kg is 3.0 x 10^8 m from the centre of the earth and directly in between the earth and the moon. find the net gravitational force on the rocket from the earth and moon.
ATTEMPT
ok so i used Fnet=( (Gm1m2)/r^2) + ( (Gm2m3)/r^2)
m1 would be the mass of earth, m2 is the mass of the rocket and m3 is the mass of the moon
what i'm confused about are the r values. for the first one i used 3.0 x 10^8 and for the second r value is subtracted 3.0 x 10^8 from 3.84 x 10^8m. is that correct?
i got a big number for the answer (2.30 x 10^9 N) so i want to make sure i understand how to do this
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jul20-11, 05:03 PM   #2
Very close; there is only one error. Hint: think about the directions of the forces.
Jul20-11, 05:04 PM   #3
i was thinking i should subtract the values because the rocket is in the middle and since gravity attracts and doesn't repel. is that anywhere near logical?
Jul21-11, 06:30 AM   #4
Quote by fa08ti View Post
Yes you are correct
Feb26-12, 09:10 PM   #5
"a rocket with a total mass of 1200kg is 3.0 x 10^8 m from the centre of the earth and directly in between the earth and the moon."
Doesn't this mean that the rocket forms a triangle with the earth and moon?
If so, would we not have to calculate the distance between the rocket and the moon, and then add the forces together to get the net gravitational force?
Or is the rocket directly in line with the earth and moon...
Mar4-12, 12:43 PM   #6
Quote by ch_advanced View Post
" directly in between the earth and the moon " would imply that all the 3 are on a straight line.
And yes, we would have to calculate distance b/w rocket and moon, though it is not at all difficult i suppose :D
And then we would simply use Sir Issac Newton's Law Of Gravitation.
New Reply
Tags
earth, gravitation force, moon, rocket
Thread Tools
Similar Threads for: net gravitational force
Thread Forum Replies
Calculate the net force pulling on Earth with phases of Moon(Gravitational Force) Introductory Physics Homework 4
How does light bend under gravitational field(gravitational force), why? Special & General Relativity 2
Balance of Forces - Electrostatic Force vs. Gravitational Force Special & General Relativity 18
Free body diagram involving normal force, gravitational force, and applied force. Introductory Physics Homework 4
Gravitational Force, the derivative of Gravitational Potential Energy? Classical Physics 3
