New Reply
Is it possible to solve this question on cross sectional area / tensile strength ?
Share Thread Thread Tools
Jul21-11, 03:13 PM   #1
A medium carbon annealed steel rod has a rectangular cross section and must cope with a tension of 3 tonnes. The thickness of the rod is 15mm. Calculate the size of the cross section.
2. Relevant equations
???? The only formula I know with CSA and force is: stress = Force / Area ????
3. The attempt at a solution
I've not yet worked out a way to even attempt an answer...
I know the load is 29430N (3000 x 9.81) but I'm not sure how to evolve this into useful data!?
Can this be solved with this level of info??
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jul21-11, 08:03 PM   #2
If the rod is in direct tension, then stress = force / area. You will need to determine the "allowable stress" of annealed steel. A good starting point for tension is allowable stress = 60% X Yield Stress. You can solve for the unknown length of the rectangle.
New Reply
Tags
annealed steel, cross section, tension
Thread Tools
Similar Threads for: Is it possible to solve this question on cross sectional area / tensile strength ?
Thread Forum Replies
Is cross-sectional area of a coil related to it magnetic field strength General Physics 1
Cross Sectional Flow Area Precalculus Mathematics Homework 1
Cross sectional area (NOT A QUESTION) Differential Geometry 3
Difference between cross section and cross sectional area? Classical Physics 0
Cross sectional area Introductory Physics Homework 2
